02-16-2012, 02:33 PM
Senior Curmudgeon
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-16-2012, 02:34 PM
Originally Posted by L.Adamson
I'm visualizing that last partial revolution of the nut..........as it get's very close to the final torque setting. Let's say that it has 1/8" of travel to go...........but the 12" bar (along with the 3" extention), is suddenly changed to 24" with a cheater. Does that last 1/8", now become 1/4, 3/16, or whatever.............because the torque setting must now be 88.9?
edit: This example would be with a click wrench
The 'movement' of the nut is irrelevant. As is the type of wrench. We are talking about torque. The nut will be in the same place after we are done with all this regardless of how we applied the torque. The question is how did we measure the torque on the nut. We are measuring the torque 3" away from the nut and that is what causes all the assumptions to change.
Phil Birkelbach
RV-7 727WB - Flying
Pitts S1C - Restoration
Christavia Mk1 - Fuselage
www.myrv7.com
02-16-2012, 02:55 PM
I must admit.............I'm ready to go out to the garage, rig up a three inch extension; torque the nut to 80 ft. lbs.; then add one foot, change the setting to 88. whatever.........and see if the nut is still at the "click" setting. If it so, then it's so.
02-16-2012, 03:06 PM
When you actually explain the compressed spring characteristics, instead of just repeating the laws of "beam" physics, then I'll be much more interested in what's said. Up to this point.................all I'm hearing is.. "because" it's written, and no actual explanation. I just figure that everyone here so far, doesn't really know...
Seriously!? This is elementary, first year engineering school stuff. It's not complicated and the fact that we are still having the discussion is becoming laughable.
I want to know, the exact workings of a compressed spring/pawl system, compared to physics and calculations derived for a beam type torque wrench. And yes, this applies to use with an extension.
None of these physics are derived from a beam type torque wrench. The measurement method has no bearing on the physics. If your physics are dependent on how you measure the parameters then there is something seriously wrong with your assumptions.
Phil Birkelbach
RV-7 727WB - Flying
www.myrv7.com
02-16-2012, 03:07 PM
Allan,
I think your wrench (and other products) are great innovations, and I wish you a lot of success. However, due to the safety factor of proper torque values, especially on a propeller, I would advise you to simply instruct people to follow the instructions in AC-43.13 for using a 3" extension on their torque wrench instead of telling them to use a constant multiplier of 0.8. Just my $.02.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
02-16-2012, 03:31 PM
One last attempt
Larry,
I'll try one more way to explain it.
Let's assume the "clicker" torque wrench is 2 feet long and the extension is .25 feet long (3").
Now put the extension on the torque wrench and you have 2.25 feet from the handle to the bolt. If you want 99 foot lbs (to make the math cleaner) at the bolt you need 44 lbs applied normal to the handle (44lbs x 2.25ft). The wrench would click at 88 ft-lbs (44lbs x 2ft).
Now leave the wrench at 88 ft-lbs and move your hand to the middle of the wrench (1 foot from the handle). Now it takes 88 lbs to get the wrench to click but the torque on the bolt is now 88 lbs x 1.25 ft= 110 ft-lbs.
Leave the wrench at 88 ft-lbs and add a 1 foot cheater to the handle. Now, it takes 29.3lbs (88/3) normal to the cheater to get the wrench to click but the torque on the bolt is now 29.3lbs x 3.25 = 95.3 ft-lbs.
The setting on the torque wrench indirectly measures the force your applying at a distance from the end of the wrench. If you're using a socket or an extension at 90 degrees to a clicker wrench then where you grab on the wrench doesn't matter much (although in reality it does introduce small errors if you don't grab the handle). But with an extension in line with the wrench, where you grab is critical to get a known torque at the bolt.
That's it for me.......
Chris
RV-8 Wings
02-16-2012, 03:36 PM
Originally Posted by Mike S
Bravo Mike!!!!
This is the best post so far!
Allan Nimmo
AntiSplatAero.com
Innovative Aircraft Safety
Products, Tools & ServicesInfo@AntiSplatAero.com Southern California (KREI)
RV-9A / Edge-540
(909) 824-1020
02-16-2012, 03:39 PM
Good...
Because I'm aware of everything you just said. But, it doesn't explain, what I'm looking for.
I've spent the last two days, scouring the Internet for the exact info I want. I've linked to numerous calculators. I don't need to hear anymore ...re quoting of the same numbers.
02-16-2012, 04:01 PM
If we aren't careful here Delta-Romeo is going to change the posting rules, No Religion, Politics or Torque Wrenches. Thanks Guys, Allan
Allan Nimmo
AntiSplatAero.com
RV-9A / Edge-540
(909) 824-1020
02-16-2012, 04:44 PM
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
