02-15-2012, 09:58 AM
Torque Wrench Question
The LONG discussion about torque wrenches reminds me of some questions that I've wondered about. I have two torque wrenches (cheap and expensive)
Is there a way that I can use wrench B to test the torque applied by wrench A?
Or, can I use my wrench that's newly calibrated to test the torque applied to a nut before calibration? (I'd check the last nut torqued before calibration to see if it was okay. If it was, I wouldn't bother to go back and re-torque everything.)
Or, can I use my basic torque wrench to test the torque applied when I use the device discussed in the LONG thread to see if 0.8 really is the correct value?
Or in general, do I just trust my torque wrench or is there a way I can test it?
Finishing -12 tail cone
-9A Empennage done, in storage
02-15-2012, 10:07 AM
Senior Curmudgeon
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-15-2012, 10:09 AM
$20,575.90????
Maybe we could get $5 off with a group buy...
Gary Hall
F1 Rocket Evo under construction
Track Links: APRS
02-15-2012, 10:16 AM
A bit hokey, but if you welded two cheap sockets together at their nut ends you could use the known good torque wrench to calibrate the other.
If the two wrenches are end-to-end the the exact same torque will be applied to both. The readings can then be compared.
Of course, this only works if one is known good, or has an exact calibration chart.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
02-15-2012, 10:51 AM
calibration
I just use a scale or better yet weights.
Weight x Arm = Moment
Set the wrench to the value you want to test. Divide that torque value by the arm. Apply weight or force to the correct location on the wrench and test. Start with a weight lower than correct and sneak up on the correct weight.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
02-15-2012, 10:59 AM
Don't even have to go that far. If you have two 1/4" drive toraue wrenches, use a 1/4" socket that is 1/4" drive on the ratchet end. Similar with any other combination of wrench drive sizes.
Kurt W.
RV9A
FLYING!!!
02-15-2012, 11:09 AM
Then use a beam wrench to calibrate the click wrench. I have 1/4, 3/8 and 1/2 inch beam wrenches...... never need calibration, but hard to use.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
02-15-2012, 12:02 PM
Err... square drive vs. a hex bolt end....
Gil Alexander
02-15-2012, 01:58 PM
Another beautiful day in paradise....N2977T
02-15-2012, 02:08 PM
Torque comparator
I have a Snap-on TCR175 torque comparator mounted on my Snap-on truck as a free service to my customers. If their torque wrench is not within specs. I send it in for calibration.
Check with your local Snap-on dealer and ask if they have one (not all do). If you're in the San Clemente/Dana Point, CA area you're welcome to use mine.
http://buy1.snapon.com/catalog/item....store&tool=all
