View Poll Results: Do you use Knots , MPH, or Kilometers To Describe Your Speed?
I use Knots. 279 74.20%
I use MPH 93 24.73%
I use kilometers per hour. 4 1.06%
Voters: 376. You may not vote on this poll
  #101
Old 02-03-2012, 07:48 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Wink It's all relative
Originally Posted by Mel View Post
I fly left seat. Ann flies right seat.
Left side of the panel is knots. Right side is mph.
She goes faster than I do, but has further to go.
We usually get there about the same time.
In a 4-place airplane I always fly in the front seat so I get there first.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 02-03-2012, 08:37 AM
John@JohnKean.com's Avatar
John@JohnKean.com John@JohnKean.com is offline
Airworthiness standards for Normal, Utility, Acrobatic and Commuter Category Airplanes, Title 14, Part 23, specify that distances are to be in nautical miles, and speeds in knots. From a practical point of view, a nautical mile is identical to a minute of latitude, a distance in nautical miles on a chart can easily be measured by using dividers and the latitude scales on the sides of the chart. OK, now I have identified myself as someone who flew long before GPS.
Old 02-03-2012, 08:52 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
You mean people actually did aviate prior to GPS? How crude!
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 02-03-2012, 09:05 AM
RV8R999 RV8R999 is offline
If we are to use airworthiness standards as the metric for appropriateness, despite lack of applicability to EAB, then I believe we should at least be consistent in their application...
ELT Ant locations
Certified GPS ant installation requirements
Pilot Operating Manuals
Adherence to engine RPM and other limits such as Vne
Max Gross Weight deviations
etc...
my .01
Old 02-03-2012, 09:25 AM
Geico266's Avatar
Geico266 Geico266 is offline
Originally Posted by rgmwa View Post
Mel, that's no help at all
But it was funny!
Good one Mel.
I always thought you were a little slower than your bride.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 02-03-2012, 09:36 AM
carlrai's Avatar
carlrai carlrai is offline
Talking I used primer...
...have tricycle gear, a slider canopy and use knots for my airspeed.
There that covers all of them.
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 02-03-2012, 10:46 AM
Steve Steve is offline
Originally Posted by Geico266 View Post
Has anyone notice the performance numbers published by Van's Aircraft for our airplanes is in MPH? Hmmmm?
http://www.vansaircraft.com/public/rv-6per.htm
Why would we change what the engineers of our aircraft have determined to be a better unit of measure?
I used both actually. Knots to flight plan and cruise. MPH to land.
My airspeed indicator has MPH on the outer (easy to read) scale so I could quickly verify my numbers against Vans.
402 hours later I glance at it occasionally like when in turbulence or while in the pattern. I think most of fly by the seat of our pants after a while anyway.
Five Sierra Fox
RV-9A
Utah
Old 02-03-2012, 01:52 PM
Mark12A's Avatar
Mark12A Mark12A is offline
Default Knots or MPH?
Think big. Use Mach.
Jay Staub
Lt. Col., USAF, Ret.
N6565S Reserved
Old 02-03-2012, 01:53 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Think real big-----use warp factor
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-03-2012, 02:03 PM
Mark12A's Avatar
Default Warp Factor?
During bomber competitions, one word indicated a direct hit:
Shack!
Jay Staub
N6565S Reserved
