Old 02-03-2012, 07:22 AM
Dennis_I's Avatar
Dennis_I Dennis_I is offline
Default Build your own ignition system?
Is there anyone out there who have built their own ignition systems? I have looked at AEM, http://www.aemelectronics.com/index.php?cPath=18_19/ But to make this work i need something to controll the sparkadvance for different manifold pressure and RPM by electronics, any ideas where they use such device?
I could just buy myself a proven good EI, but whats the fun in that?
And it is a small father and son contest, because in late 80`s my dad modified two Suzuki GSXR 750 ignition systems and used them on his RV-4 with great results. So it would be fun doing something similar....
Pic of the Suzuki systems coil set up
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
Old 02-03-2012, 07:36 AM
rocketbob's Avatar
I built one with a PIC micro, an IGBT, hall-effect pickup, some resistors, caps, etc. on a breadboard, hooked it all up to my lathe, and was firing a GM coil pack. That's as far as I got. Its a subject I will definitely revisit in the future.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-03-2012, 07:56 AM
Phlyan Pan Phlyan Pan is offline
I built a megasquirt system on a VW rabbit race car once. Does that count?
Old 02-03-2012, 09:39 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
The man to talk to would be Mark Landoll. Contact him and I guarantee you will know more than you did before you met him.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 02-03-2012, 10:13 AM
DanH's Avatar
DanH DanH is online now
Built a dual ignition for a Suzuki conversion using ND pickups, GM modules, and (if I remember correctly) Toyota coils, a system pioneered on the old AirSoob list. Worked great.
Dan Horton
RV-8 SS
Barrett IO-390
