02-01-2012, 01:59 PM
alternative Jack
in our hanger (two RV's) we use a HF motorcycle jack that has a flat platform top. One of the guys built a box to fit on top of it that extends it and has the appropriate contour to fit under the cockpit at the spar carry though. We use a furniture pad for additional padding.
It nicely raises the whole plane, and with slight adjustment, can lift just the nosewheel.
Jim F
RV-9A (220 Hrs.)
02-01-2012, 05:11 PM
The jacks are now listed on Harbor Freight for $54...
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
02-01-2012, 06:24 PM
Just finished the Tie-Down assemblies on the two Spars. Had no idea they were that strong!
- John Munroe
Front Royal, VA
RV-8 in progress
02-01-2012, 07:46 PM
Use coupon code winter10 and save 10% plus $6.99 shipping.
John Mastro
RV-8
02-01-2012, 09:12 PM
They put them on sale often. I just picked up 2 of them last week at one of their stores @$39.99 each.
David C.
Howell, MI
02-02-2012, 06:20 PM
Went to visit local store, the jacks were labeled $39.99!! At the register, they were $54.99.
The manager honored the $39.99 price AND applied my 20% off coupon!
Total price was just over $29 each!!! I'm gathering the other parts and will put my Frankenstein jack together soon. THANKS for the great idea!
Track my RV7A!!
02-02-2012, 06:44 PM
Senior Curmudgeon
I built these a year + ago, have worked well for me.
I welded the jacks to steel plate, about 14" square, 3/8" thick.
Bit heavier than the ones shown at the start of the thread, but totally no way they are going to tip over in normal use.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
02-03-2012, 07:11 AM
Here's how I capture the wing bolt without worry of it coming off the jack. I JBwelded the wing nut on (backwards) so it is easy to spin the bolt in and out of the wing tiedown. The oversized hole allows for the slight angle of the bolt in the hole. I also notched the top of the legs to keep the band clamp in place.
greg
Greg Arehart
N 7965A
02-06-2012, 02:35 PM
Finished my jack project today. I am quite pleased. I used Greg's technique and drilled a hole in the jack shaft to accept the bolt assembly that screws into the tie down hole.
Anyone who wishes to borrow these jacks is more than welcome. I do charge Russians $20/weekend rental fee.
Track my RV7A!!
02-06-2012, 03:41 PM
Got mine done
The jacks are $54 now. I over did the bases a little, but very stable while jumping in and out of various RV's. The 3 inch exhaust clamp worked well for securing the 3/4" conduit to the jack body. My hanger always floods about a inch deep after a rain, so decided against the wood base.
Jason Krause
RV-7 SB Finish Kit
Flying other people's stuff RV-9, Kit Fox.....
www.JDair.com
RV accessories including TailWheel Steering Links,
Upgraded Tailwheel Forks and Rudder Pedal Extensions.
