Old 01-28-2012, 11:51 AM
CMBAero CMBAero is offline
Default 4" yoke vs 3" yoke...
Hey guys,
So I was getting ready to pass an order on ATS for some missing tools and this included a longer yoke for my squeezer... well I needed deep reach and now I can't decide between 3" and 4"...my guess is take the 4" because for ~10$ more it can go deeper and you can use it at the same spot that requires a 3"... so my question is, why would someone buy both or decide between those two!?
3"
https://www.aircraft-tool.com/shop/d..._ID=ATSRS-3SDY
4"
https://www.aircraft-tool.com/shop/d..._ID=ATSRS-4SDY
Old 01-28-2012, 12:32 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Sometimes, you might need at least a 3" yoke, while the 4" just won't fit into the space.......because of other structure. It's why I had both.
Old 01-28-2012, 12:45 PM
Okk! But for the empennage of the RV-9A, which one would you recommend first? 3" or 4"
Old 01-28-2012, 07:38 PM
Wayne Gillispie Wayne Gillispie is offline
I only had the 4", but could have used the 3" in places. Also an alligator squeezer would have been nice in many other places.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-28-2012, 09:30 PM
bruceh's Avatar
bruceh bruceh is offline
I have a 3" with hole, a 4" no hole, and a longeron yoke. You will need all of these at some point in the build, so go ahead and buy them. There are also a few times in the build where a 2" yoke would be nice to have (but not essential like the others listed). If you are worried about spending a couple of hundred bucks at this point, then just wait until you are buying avionics and an engine! You can always sell the yokes later to someone else. Buy them all now and you will thank me later.
Bruce Hill
2020 VAF donator
Old 01-28-2012, 10:13 PM
AltonD's Avatar
AltonD AltonD is offline
4" yoke
no hole 4" yoke
longeron yoke
I built a slow build with only these.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 01-29-2012, 09:07 AM
rleffler's Avatar
rleffler rleffler is offline
I agree and did the same as Bruce.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-29-2012, 09:17 AM
Hey Bruce,
I know exactly what you mean and I feel the same way about buying it all, but the problem is I started the build while I am still in school to finish my A&P, so I have to fit the expenses for tools in my budget since I don't have a stable revenue for now, so I can't just go and buy all of it now until I'm done with school in may.... need money for other crucial tools, like bucking gun and DRDT...
With that being said, that's why I was asking which one is more important for empennage...
As for the 4" no hole, ATS doesn't make one for the Stainless Heavy Duty Squeezer...? :S
only a 4" hole, 3" hole, Narrow Yoke no hole, Longeron yoke with hoke....
Old 01-29-2012, 09:42 AM
RV7ator RV7ator is offline
The 4" yoke deflects too much often resulting in canted rivets, especially 1/8. Always use the stiffest yoke - like the 1 1/2" - that provides the needed grip. 3" is marginal. There are so few places that are beyond a 3" but accessible with a 4" before you must reach for the gun it's rather a waste of money. Look beyond the emp for your dollars. Longeron and no-hole yokes have many uses throughout the build.
John Siebold
Old 01-29-2012, 11:05 AM
bruceh's Avatar
In order of usefulness (my opinion) Longeron yoke, 3", then 4". I understand about the budgetary needs. I too at one time was hoping to do this build on the cheap, but at some point you realize that you will need the 50 to 75 grand to get this airplane completed. If the tool budget is tight now, you will never get past the empennage kit. Van's makes it easy to get a hit off the old crack pipe with the tail kit being fairly cheap. In the big scheme of things, the cost of tools is insignificant, and you will later wish you had just bought them all up front.
Bruce Hill
2020 VAF donator
