View Poll Results: Do you use Knots , MPH, or Kilometers To Describe Your Speed?
I use Knots.
279 |
74.20% |
I use MPH
93 |
24.73% |
I use kilometers per hour.
4 |
1.06% |
01-28-2012, 05:36 PM
Mph is easier
A mile is based on 1,000 Roman paces.
A nautical mile is one minute of latitude.
Charts use latitude and longitude, and thus have distance scales all over them.
Sectionals are charts.
But if you want to use miles all you haft to do is measure the distance against the latitude scale to determine the number of minutes multiply by 6,080 (apx) and divide by 5,280.
Who uses Mach?
01-28-2012, 05:42 PM
Knots
The earth is surveyed in Deg, min and sec. 1 Minute of latitude is 1 NM, anywhere.
The cosine of your Lat position is equal to the decimal value of one Minute of Longitude at your current Lat.
It's the foundation of all naval and aviation navigation.
01-28-2012, 05:44 PM
Knots fit well with charts and winds.
Jim Sharkey
RV-6
01-28-2012, 05:46 PM
Who uses Mach?
True story, happened to a friend of mine instructing in a T2. The T2 was slow but could fly very high. I don't even think it had a mach meter. Flying a new student on his first cross country. Near El Paso at 39000 feet they are asked to say their Mach. The student quickly replied that he was Maching the 090 radial at 78 miles. The follow on laughter on the control freq my friend found quite embarrassing!!! A discussion with the student on the ground about the difference between Mark and Mach took place.
George
01-28-2012, 05:47 PM
I use knots for airplanes - even a Stearman (which makes for some really sad numbers). The only time I use MPH is when talking to my mom because she can understand MPH.
KMH are faster
Km/h are faster come on guys I can not be alone in the poll. Who else is using metrics?
01-28-2012, 06:04 PM
I use kts and mph depending on the situation
Saying speed in kts to a driver gives them a unit of measure that means nothing except in their mind the airplane is slower than it really is.
When talking to pilots and ATC I use kts.
When reporting race results I use both because you don't know the preference of the reader.
I guess I can't vote.
Bob Axsom
I voted KM/HR because it doesn't mean anything and I was tired of Vlad sitting there all alone.
01-28-2012, 06:30 PM
Who uses Mach?
They must have had long legs
01-28-2012, 06:46 PM
Knots. A statute mile per hour means nothing to me.
Aside from the minor fact it's impossible to get a plane certified here with a mph airspeed indicator, 1 knot = 1 nautical mile per hour = 1 minute of latitude per hour = graduations which are marked on aeronautical charts the world over = internationally accepted aviation standard for airspeed/tas/groundspeed.
If you can read lat/long on an aeronautical chart, then you know what a "nautical mile" is by default. If you can't read lat/long on an aeronautical chart, why are you flying a plane? I've never understood the morbid fascination with continuing to measure speed in statute miles per hour in an aircraft.
Mike
Down Under
No offence intended!
01-28-2012, 07:23 PM
RV's are fast enough to use Knots and get respectable numbers..well OK, not the RV12...
The serious answer is one talks to ATC continuosly while flying IFR, speed comes up quite often (either cus there is a Cessna put put in front of you or a jet behind you) and your better off using the same language.
As an engineer that is fluent in both metric and Imperial units, I have to say the metric system is by far the best.
You have no idea how hard it is for an English guy to admit that anything invented in France is better..
