Old 01-24-2012, 05:22 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Mouse Milk
Until I learned that Larry Vetterman recommends the use of Mouse Milk on the ball joints of exhaust systems, I was only dimly aware that the product even existed. After including a bottle of Mouse Milk with the most recent parts order with Spruce, a bottle of MM will now share permanent shelf space with other maintenance items supporting my projects.
The label on the bottle itself reads like a magic elixir speil coming from a snake oil salesman and I can understand that. A review of the archives didn't provide all that much information, so I am asking. Besides using Mouse Milk as a proactive to periodically lubricate exhaust system ball and slip joints, I'm interested in know what other specific situations RV owners have found Mouse Milk to be useful.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 01-24-2012, 05:29 AM
pmccoy's Avatar
pmccoy pmccoy is offline
My throttle cable was a bit sticky..., my A&P said to apply some MM down the cable to loosen it up a bit. Worked great.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 01-24-2012, 05:50 AM
LR60 LR60 is offline
Default Ever milked a mouse?
Reminds me of "Meet the Parents" when Gaylord Focker talks about milking a cat?
At my old job we used it to free up seized bolts/pins/parts...Landing gear trunion pins...TR bolts.....etc
I used KROIL or mouse milk which ever was closer to me, they both seemed to work very well with some heat and pressure to free up seized parts.
....and like you, I like telling people that I got their "part" loose with mouse milk.....you would get some odd looks.
Mark
RV-8 Emp (built/sold)
RV-14 (in-work)
Old 01-24-2012, 06:13 AM
Geico266's Avatar
Geico266 Geico266 is offline
You should see the set up Aircraft Spruce has to milk mice, hard to get the little suckers to hold still.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 01-24-2012, 07:26 AM
totally off topic ...
http://tgmouse.compmed.ucdavis.edu/milk/momilk.html
But Larry brought it up.
As for the aircraft compound, I'll need to try it on the cables. Thanks for the tip.
Old 01-24-2012, 07:51 AM
JonJay's Avatar
JonJay JonJay is offline
I use it as a cutting lubricate for drilling, lathe work, tapping etc.... on steel parts.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 01-24-2012, 08:13 AM
flyboy1963's Avatar
Default ...could it all be the same?
Now wait, you're using it for drill lube?....could it be that Mouse Milk is just BoeLube , thinned down with mosquito saliva?
Are 67% of the world's products really coming from the same bucket?...just frozen, thinned, coloured, or re-packaged & branded?
( the first time I saw a tube of BoeLube, I said.....'this is like the little roll of 'lip balm' stuff that I used to lubricate the cork on my saxaphone with... in high skool!!!")
...another good 'consipiracy' theory anyway!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 01-24-2012, 09:09 AM
Jim Percy Jim Percy is offline
Not very specific, but I use MM for EVERYTHING that calls for a light/penetrating type oil, at the hangar and at home. I think it's great stuff- penetrates well and lasts well too. That little can of Marvel Mystery Oil has been pretty lonely since I learned about MM...
(Edit: I guess I shouldn't say "everything" because I do use Boelube for a few things: solid for first-time threading in a nutplate, and liquid as cutting oil...)
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 01-24-2012, 09:10 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
It's a good penetrating oil for really stuck fasteners - like the O2 sensor on your car...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-24-2012, 09:44 AM
JonJay's Avatar
I use Biolube on Aluminum and MM on Steel. I am not really sure what the base chemical is for either of them, I suppose I could look it up.
Unless you are doing industrial production work with hundreds or thousands of operations, I think almost any lubricant will work on almost anything. I have used tool oil, engine oil, kerosene, ear wax, belly button sludge, whatever is handy.
There are differences that I am sure would affect tool life etc... However, for our homebuilding, we don't need to be that specific in my limited experience.
But for penetrating oil to loosen parts, nothing works better than MM.
Bucker Jungmann
RV1 - Proud Pilot.
