Old 12-21-2011, 06:38 AM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
Thumbs up Up North Aviation
I am putting a new panel in my RV-4. I was looking for someone to help me design the panel around my current instrumentation, then cut the panel for me. I ran across Bill Morelli of Up North Aviation in VT. I contacted Bill and told him what I was looking for, and he jumped on board.
Bill laid out my panel, making as many changes as I wanted, working until I was satisfied with the result. He sent full size drawings that I printed at Staples to check in the plane.
I sent him my Vans panel blank and he CNC cut it perfectly. His e-mail response was always quick, and his price for the work was very fair. Panel turnaround was only days.
I recommend Bill to anyone looking to have a new panel designed and cut.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 12-21-2011, 09:56 AM
Billvt's Avatar
Billvt Billvt is offline
Default Up North Aviation
Here at Up North Aviation, I pride myself in offering:
- Timely responses to your e-mails
- No additional charge for unlimited CAD design
- Rapid turn around of the panel fabrication
- Cost that is very reasonable.
If anyone would like additional information please visit my web site ( see below), check out the testimonials and contact me from the web site or from here at upnorthaviation@gmail.com
Bill Morelli - A&P I/A - EAA Tech Counselor
Up North Aviation
CNC Instrument Panel Fabrication
Web www.upnorthaviation.com
E-Mail upnorthaviation@gmail.com
- RV-4 build in progress !!!
Old 12-21-2011, 02:00 PM
DanBeadle DanBeadle is offline
Default Excellent Service, Great Panel
I made a very complex panel for my RV8. It is jam packed with equipment behind the panel
Bill Morelli was great help to making this all work the first time. I had done some sketches, but Bill made them real. We went through several refinements of the panel. Bill picked up a lot of little details. For example, the radios need 0.040" between them to allow the extraction mechanism to work. And, of course, I changed my mind a couple times. Bill cheerfully incorporated the changes.
Between us, we designed a panel that can be removed from the RV8 for service. That is important- with all the wires, changing them from underneath would be a real pain.
The design work was excellent. The production was flawless. When I actually got the panel, it was exactly what I expected. Now that I am through installing equipment, I can attest that Bill's attention to detail was spot on.
See more pictures:
CAD Drawing
Powered Up
Old 12-21-2011, 03:48 PM
cbennet1 cbennet1 is offline
+ 1 from me. Bill cut a panel for my RV6 that went through countless iterations as I constantly revised my layout and tweaked measurements. Bill responded instantly to each adjustment and I couldn't be happier with my new panel.
Craig
Craig Bennett
321GT Flying RV6
2018 dues paid, how about you?
Old 12-21-2011, 05:16 PM
gordodavis gordodavis is offline
Smile Excellent Service and Product
I had Bill at "Up North Aviation" cut my panel. I couldn't be more pleased with the friendly service I received and the product that was delivered. Bill worked with me each step of the way. I started off by giving him a drawing that I created in photoshop and he converted it to AutoCAD for me. Since I have very limited AutoCAD experience, this was a great help to me. Bill researched the make and model of each switch, light and instrument that was being installed in my panel to insure the proper size. As I have been installing my equipment, I'm constantly amazed how accurate each hole has been cut. I totally recommend "Up North Aviation".
Old 12-21-2011, 06:08 PM
logansc's Avatar
logansc logansc is offline
+1 on Bill Morelli's service. Not only did he do a super job on my panel (including a number of in-progress changes), he has followed up with me on several occasions, to be sure that I continue to be satisfied with the results. Truth is, I couldn't be happier with it.
Good vendor, definitely focused on quality and customer satisfaction!
Regards,
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
Old 12-23-2011, 06:24 PM
flybye flybye is offline
Another recommendation for Bill at Up North Aviation. He'll work through a design interactively. He's knowledgeable of the requirements with fast turn-around. I wouldn't hesitate to use him again for a panel.
Robin
RV9a
Old 01-01-2012, 11:07 AM
kevin O kevin O is offline
Default Engraving
Do you intend on offering engraving services
Old 01-01-2012, 11:54 AM
awlbidnes awlbidnes is offline
Add my name to the thumbs up list for Bill. I'm just now populating and wiring instruments into the -8 panel that he cut for me but EVERYTHING FITS!!! Highly recommended.
Larry Scott
Hobbs, NM
RV-7 N712CT "La Otra Mujer" Flying
RV-8 In progress
Old 01-22-2012, 05:28 PM
bryanflood's Avatar
bryanflood bryanflood is offline
Default Thumbs up for up North Aviation
I have to say that I was extremely pleased with the work of Up North Aviation. Bill, the owner, was easy to work with and very helpful. Bill went the extra mile to make sure I got exactly what I wanted. Not only was the price extremely reasonable but the results were much better than I could have ever produced on my own. I will never cut another panel on my own again. Highly recommend Up North Aviation.
Bryan Flood
