Old 12-21-2011, 03:47 PM
Planenut Planenut is offline
Not that simple, my RV7-A has a tubular landing gear while my -8 has a leaf spring gear. It was easy for the -8 simply purchase axles and just put longer bolts to mount the second axle internally opposite the wheel axle.
A tubular gear will require a much more complex attachment fitting and modification to the axles.
Patrick
Old 12-26-2011, 05:26 PM
Today's test flight in 10 inch of powder Awesome smooth as silk!
Cruised at 135 kts no flutter
Old 12-28-2011, 09:35 AM
riseric's Avatar
riseric riseric is offline
Hi Patrick,
Very well done indeed !!!
I will be starting a QB-8 soon (in Europe) then planning on finishing it in Quebec when my work here is done...
So snow skis are definitely an interesting option !!!
Keep up the great work !!!
Eric
Oh, BTW, can't see your pics in Flickr as they are "private"...
Old 12-28-2011, 04:47 PM
SHIPCHIEF SHIPCHIEF is offline
Thanks for sharing the pictures and results.
I see lots of potential for these skis.
For overwater flights, a ditch in the case of engine failure would be much less violent, same for a landing in an unprepared field.
Are you considering making these for the group or providing plans when you get it perfected?
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 12-29-2011, 08:14 AM
If I get many requests I may consider either selling kits or plans w bill of materials may also consider selling my design. I also installed mirrors so I can check the position of the skis just after take off. If you want more photos or information email Kitfox.rv@gmail.com
Old 12-31-2011, 02:13 AM
NickAir's Avatar
NickAir NickAir is offline
Location: McMinnville, Oregon: HOME of the SPRUCE GOOSE
This is impressive.
Did you use the factory Van's gear legs or Grove gear legs??
Nice.
Tailwinds...
Simplicity is the ultimate sophistication.
Leonardo Da Vinci
Working on a RV-4
Citabria 7GCBC
Cessna 180, sold
RV7 I0-360 C/S, Slider, AP, Glass, etc. sold.
RV6 O-320 F/P, Slider, AP, Steam, etc., sold
Citabria 7KCAB rental
Piper Cherokee, sold
Sparrowhawk, sold
Proud -VAF- Supporter - Exempt, Dues Paid Anyway.
Old 12-31-2011, 07:01 AM
Thank you
I have Grove gear installed on my RV 8 and I have the original new pair of Van's my wheel skis would fit on them also.
Happy New Year to all Van's Fans!!!
Old 01-09-2012, 07:20 AM
Default Frozen RV Grin
I now logged 3.5 hours and 20+ T/O & landings in 10 inch power, 4 inches slush, packed power, rough field 5 inch snow, taxiing through 15 inch drifts no issue at all with my wheel/skis on my RV8. New project for next winter design wheel/skis for my RV7-A.
Patrick
Old 01-09-2012, 09:33 PM
Tricycle ski gear?
That sounds interesting and requiring of inventivness (is that a word?)
There are a lot more 6a, 7a, 8a, 9a's than RV-8s. That would be a bigger customer group.
Scott Emery
2019
Old 01-22-2012, 08:08 AM
Got stuck yesterday while taxiing off hard pack snow. Skis broke through a 3 inch ice crust with 12 inch of power under it. I shut down, broke a trail pushed away the chucks of ice crust so that the prop would not get damaged. Powered up and taxied back to the hard packed area without furteher issue. Also landed on the Ottawa river snowmobile trail, thick tracks requiring caution and took off through a slush area, only found out after doing a fly by to verify my tracks in the snow. Hoping to find a way of providing photos for everybody.
