Old 09-27-2011, 03:50 PM
rcarson rcarson is offline
Default Aileron Trim Question
I recently installed the aileron trim kit and it seems there is a lot of tension on the springs. I set it up the way it was described in the instructions but when the stick is moved normally it puts a lot of stress on the servo assembly. Has anyone else had trouble with this or is this the way it is supposed to be and can someone tell me if it works well in flight? Thanks for the input.
Old 09-27-2011, 07:45 PM
taflores taflores is offline
Mine is the same way on my RV-7, in fact I installed needs springs, because the last owner hacked them all up, because he did not know what he was doing, he was trying to correct for a heavy wing so the idiot cut the springs shorter. My trim seems to work fine in flight, I need to correct for a heavy wing issue though, I will start with the rigging set up on the plane, I am told to take her up to cruise alt. and power setting and take my feet off the rudder pedals and see where the ball is, then start by setting up the rudder, i may need a trim tab on mine.
Old 09-27-2011, 07:53 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
People seem to resist doing this but bend up a small tab and tape it to the underside of the elevator and see if that frees up the inflight loads.
Your electric trim really should only be used for in flight levelling of the plane due to fuel loads changing and say only one POB and fuel.
Will make life much nicer!
Old 09-27-2011, 07:55 PM
The important issue is being able to move the stick full throw no matter where the trim springs are positioned. They look stretched as installed per the instructions but they will stretch a lot farther when you do this check.
Mine works fine except I need to tighten the friction bolt a bit. Moving the aileron sometimes will move the trim handle also.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 09-27-2011, 11:02 PM
Bavafa Bavafa is offline
I don?t think there needs to be any load on the servo in the neutral position. Mine with a manual trim is set that there is hardly any load on the spring on either side when it is in the neutral position. Of course if you want to compensate for a heavy wing (wrong way to go about fixing an issue) then you may need even a heavy duty spring (NOT recommended here)
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 09-28-2011, 06:41 AM
There is no tension on the mechanism in the neutral positon so I guess it's alright. I am trying to finish by the spring of 2012 but don't want to reinvent the wheel. Thanks for all of the imput, it looks like it's the way it's supposed to be.
Old 09-28-2011, 03:32 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
We did this to my plane, I can trim and fly hands free now
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
Old 01-21-2012, 02:58 PM
Homie Homie is offline
Talking Heavy Wing
Can you shoot a photo of the tab you put on the elevator to relieve the heavy wing condition? Post it here or send to jhomsley@cebridge.net.
Thx
Old 01-21-2012, 03:11 PM
gasman gasman is offline
Did you really mean this??....................
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 01-21-2012, 04:51 PM
ghatch ghatch is offline
Hi Richard,
I've been thinking about adding a manual aileron trim to my 7. I would love to see a picture(s) of your finished install so that I can get an idea of what is involved.
Gerry
