Old 01-14-2012, 07:31 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Stuck Impulse Coupler? Stranded (Sorta
OK, here's a quick one for the experienced mechanics reading this morning because it's too cold to go outside....
We had to leave the RV-6 up on the ramp in College Station yesterday evening - wouldn't start. They have no pre-heat or hangars available, so we ran the battery down trying to get it to fire. I then went to hand propping, and had similar luck. We did manage to flood it, as evidenced by dripping gas at one point, so I know there is fuel.
I woke up in the middle of the night while mentally making a "tool list" for today's rescue mission, and realized that i was getting no impulse coupler "clicks" as I was hand propping - so I suspect the IC is stuck/broken...not working.
So...I anticipate pulling the mag to check this - any advice on how to check it, what to look for - or how to pull it in the field? I have two other mags with good impulse couplers but bad coils - I can't recall having pulled an IC before - do I need any special tools?
Headed up there when it gets warm this afternoon if anyone has any good words. It's good to have multiple airplanes at times like this....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-14-2012, 07:34 AM
Brantel's Avatar
Brantel Brantel is offline
Paul,
Just be sure that if the impulse coupler broke, that no parts fell into the accessory case.....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-14-2012, 07:41 AM
rocketbob's Avatar
Sometimes the impulse couplings won't snap if the oil is cold and the springs are weak. I would make an effort to give it a good preheat and not try to fix that on the ramp. You've likely not endured the pain of rewinding an impulse coupling spring...trust me you won't want to do it away from home. Bring a can of starting fluid (ether).
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-14-2012, 07:45 AM
Dave62 Dave62 is offline
Cant pull the impulse without a special puller or you can damage the mag. Would be better to pull the coil and change but that too requires a special tool if it is a Slick mag. The coil is held in with wedges that can be quite tight. If Bendix the coil comes out very easy. To check impluse just make sure the palls can swing free and catch on their stops on the mag case with the mag in the position it would be in on the airplane. If they are tight or gummed up they sometimes will not work free and not catch ....especially when it is cold. Also check for broken spring...although I have never seen one break. Uou can feel the impluse wind up as you turn over the mag. It is best not to snap the mag as it can cause carbon tracks in the mag distributor block unless you put wires in each hole and ground them to the mag case.
Dave (Swift Driver)
Old 01-14-2012, 07:50 AM
Walt's Avatar
Walt Walt is offline
Paul,
I have a slick mag with impulse coupler in my tool box, I'll fly it down to you on my way to Hicks if you need it, I can also bring some tools with me.
I also have a PC680 charged and ready to go.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 01-14-2012, 08:33 AM
Brantel's Avatar
Something tells me that the 6 will be getting P-mags sooner rather than later....
Old 01-14-2012, 08:53 AM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Default these videos might help you out.
http://www.youtube.com/watch?v=FAcIThVWAeQ
http://www.youtube.com/watch?v=EpHgRyBWvI4
http://www.youtube.com/watch?v=RsdiIZwdth8
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 01-14-2012, 09:08 AM
170 driver 170 driver is offline
I have had success by pulling the mag and washing the impulse while it is still on the mag in avgas and relubing it with light oil , they get gummed up since they are on top of the accessory case and all the evaporations from the lower case end up there.
Jim Poe
RV9 First Flight 2/23/09
s/n 91416
Old 01-14-2012, 09:15 AM
Ironflight's Avatar
Great inputs from everyone - thanks! I knew that there were some tricks to workign with the IC (thanks for the videos Russ!), and having dealt with more than a few lawn mower recoil starter springs, I wasn't looking forward to exploring this in the field.
Walt - I might give you a call up at Jay's - we are not going to get up to KCLL until early/mid afternoon (it's gotta warm up before we do anything) regardless. If you had that with you today, it woudl be great!
So another question - if it's just hung up because it's cold and the grease is sticky, has anyone just pulled the mag and (carefully) shot the IC with LPS to free it up? {ed - Ahh...I see Jim answered this one while I was typing - thanks!}
Yeah, we're going to have to look at long term solutions, but just want to get it home first...
Paul
Paul F. Dye
Old 01-14-2012, 09:45 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
What do you mean by "warm up?"
You are in southern Texas.
