Old 01-10-2012, 07:57 AM
Iluke Iluke is offline
Default Priming rack ideas?
I'm looking for good ideas for a priming rack. I'm setting up my shop, getting ready to start an RV-7, and I'd like to have something ready for spraying primer on parts that won't make a mess or aspyxiate me.
I have a nice, heated garage to work in, and I'm thinking of building some sort of expanded-metal table-top rig with a down draft blower exausting thorugh a hose to the outside.
Anyone have some good or bad expereince in this area? Specifically, what size surface do I need (i.e., what's the largest part I will need to spray?) Also, any thoughts on how much airflow will I need & what's the most cost effective source/type of fan?
Old 01-10-2012, 08:03 AM
No real thoughts on the exhaust system, but a window screen with aluminum fabric is great for a work surface. No problems with small stuff falling through it & virtually no effect on spray patterns.
Charlie
Old 01-10-2012, 08:56 AM
flynwest flynwest is offline
Default chicken wire
Chicken wire sandwiched between 2X2's for the spray table. Mine was about 3' X 5' spay near the door with a fan blowing out.
Old 01-10-2012, 09:05 AM
airguy's Avatar
airguy airguy is offline
I took at 2x12 and wedged it between the floor and the ceiling (make sure you hit a ceiling joist runner, or you'll punch through the sheetrock) then screwed 1x2 runners horizontally to that, and used a brad nailer to put a few dozen finish nails in the 1x2's. Hang your parts on the finish nails and spray away.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 01-10-2012, 09:13 AM
David Z David Z is offline
Default Simple
Mine was made from mechanics wire hanging the parts off the forks on a fork-lift. My point is it doesn't need to be fancy, just something that works.
Anywhere that you can hang it, and you don't mind a bit of overspray. Kid's swing set on a nice day? Just use a chemical mask! Mine cost more than my spray gun.
I do like Greg's idea.
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage deburring and dimpling. So many holes
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 01-10-2012, 10:14 AM
Good ideas, thanks! Is the consensus that it is better to ahve parts hanging than laying down on a screen?
Old 01-10-2012, 10:29 AM
Danny7 Danny7 is offline
might be a little easier to have them hanging, but more importantly is to go and build your plane, not talk about priming
seriously, do a good job priming the bare al, do whatever you think best for the alclad and get building!
nothing special here...
Old 01-10-2012, 11:08 AM
selhardt's Avatar
selhardt selhardt is offline
Default Simpler
I built a screen covered rack and never ended up using it. I found that I had to turn things any way so I just used cardboard on the floor (my car was outside any way :-))
I too built in my heated garage - I wore a respirator when I primed and cracked the big door in the winter and left it open in the summer. (How else are you going to have your neighbors tell you they'd never fly that thing).
I agree with Danny7, for i=1 to done, build and prime, don't fret too long.
Scott Elhardt
RV-8 N32SE -Finished!
Grove Gear, XIO-360-M1B
Whirlwind RV200
Dual PMags
Pitts S-1S Restoration in process!
Minneapolis, MN
Old 01-10-2012, 11:11 AM
Wayne Gillispie Wayne Gillispie is offline
I used a 12" axial flow duct booster, 2' X 5' plywood box, 1/2" hardware cloth, exhausted out a window, closed off remainder of open window. I also hung parts. I did not prime most alclad stuff. With 27 hrs on it, it has not corroded and fallen from the sky. It also turned my slow build into a quick build. Just depends on where it is based, how soon you want to finish, how much you want to spend and what you want to breathe into your lungs/absorb into your skin. Yes, I wore a respirator and nitrile gloves, but if you paint inside in the winter you will still have some residual in the air even with exhaust.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-10-2012, 02:10 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default My Solution
A bottom skin from my RV-7 wing gives the photo some scale. Mesh on top is "chicken wire" with about a 1/2" grid size. There is baffling in the box to settle out most of the overspray before it is drawn through a 20" square filter on the bottom by a fan strapped horizontally to the bottom of the table.
This seemed to take care of almost all of the actual overspray. What you can't see in the photo is an industrial exhaust fan through the wall above the table which takes care of ventilation and fumes.
I have used this setup for the last 5 years and found I could prime without getting paint overspray all over the shop. I had to resort to other means for some of the larger fuselage skins and really long parts but this took care of virtually everything else. It has been really nice being able to prime and paint pretty much at will without issues from weather, etc.
Dan Langhout
2021 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
837 hours and counting . . . .
28 Pilots N Paws Flights
Now based at Moontown (3M5)
