01-02-2012, 11:15 AM
Fuel tank leaking through plate mounting screws/nutplates
Hi all,
I am having issues with fuel leaking through the screws mounting the float plate to the tank. Since my kit was a QB, I did not have the option of using sealed nutplates. I now have a conic leak no matter how tightly I tighten the screws. Is there any sealant that I can put on the screw threads (LocTite or otherwise) to prevent the seepage?
Gerry
01-02-2012, 11:39 AM
Chunk the cork gasket and use pro-seal is what most people do for this.
http://www.vansaircraft.com/cgi-bin/...roduct=proseal
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
01-02-2012, 11:58 AM
EZ TURN LUBE
I had the same problem and fixed it with EZ TURN.
You will have to drain or fly off the fuel to about 2 gallons otherwise the fuel will drain out the screw hole. Remove one at a time and spread EZ TURN on the threads and install. http://www.aircraftspruce.com/catalo...ezturnlube.php
Best,
Rich
Rich Rudolph
VAF#007
RV6A 2000 HRS.
Fort Worth,Tx.
Wright Brothers “Master Pilot” Award
01-02-2012, 12:17 PM
Originally Posted by rich
Formerly known as Fuel Lube.
Alton DeWeese
N4IDH
Construction Log
?Mark Twain
01-02-2012, 02:30 PM
VAF Moderator / Line Boy
I'd be interested in seeing how the fuel lube will work in the long term....I'd go ahead and re-install the screws, encapsulating them with pro-seal. Thousands are done that way, and you never have to worry about it again.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
01-02-2012, 07:36 PM
We used the Permatex Aviation Form-a-Gasket (sticky brown stuff) on the screws, nutplates, and cork gasket. No leaks in a year and a half on the RV-8. Also no leaks in 7 years on a similarly-prepped RV-4.
Neal Howard
Airplaneless once again...
01-03-2012, 09:15 AM
Thanks guys for the quick and varied solutions. I need some pro-seal on hand so, I think I'll start there.
Thanks again,
Gerry
01-03-2012, 09:29 AM
Gerry
The proseal is the way to go, I put a little on the threads screw it in and then cover the head with a bead of the stuff. If you want to make it look neat as the sealer begins to set wet your finger (rubber glove maybe) with a little soapy water and push/mold the bead to a nice rounded dome over each screw.
Jerry
01-03-2012, 09:33 AM
Fuel leaks
For my 6A, the fuel system is the weakest link. In the course of removing the slosh, I cut new access ports in the rear tank wall. I installed the stock cork gaskets with 'fuel lube' and they held so far. The rubber gaskets for the fuel senders leaked when installed with the lube. I must have torked them too much. I removed the rubber gaskets and prosealed the senders metal to metal. On the up side, I can remove a tank in 40 minutes but I don't enjoy it as much as I used to. The old cork was seeping very badly at 10 years and 700 hours.
John D. Artz, EAA 71811, 100+ Young Eagle flts
Adopted Dave's 6A
MXL Ultralight, only bleeding after 3 landings
Scorpion Two Helicopter, big mistake
PA-28 and 210E Centurion
01-03-2012, 10:10 AM
Originally Posted by Cadstat
...In the course of removing the slosh, I cut new access ports in the rear tank wall. I installed the stock cork gaskets with 'fuel lube' and they held so far...
John,
I just cut four access holes in the rear wall of my RV-4 left tank. I have a number of leaks and figured it was best to open the tank, clean everything, then pro-seal all seams. I cut four plates to rivet over the holes, and was going to pro-seal metal to metal. I am unclear from your comment above whether you used the cork gasket on the rear wall access ports, or on the rib access hole and fuel sender hole. If on the rear wall, can you elaborate on why you used cork instead of pro-seal the covers on?
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
