Old 01-02-2012, 08:08 PM
papamike's Avatar
papamike papamike is offline
Default 12V or 24V?
I apologize if this has been asked before. What is the consensus on whether to go 12V or 24V? I've been reading Aircraft Wiring for Smart People and he brings up some good points about using 24V.
Pete Miller
RV-7 Panel and Avionics
N174PM (reserved)
McKinney, TX (T31)
http://smilinpete.com
Old 01-02-2012, 08:14 PM
Wayne Gillispie Wayne Gillispie is offline
I would say 12 Volts for 99% of us. Yep it has been discussed, but not like primer. I am very happy with my 12 V system.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-02-2012, 08:21 PM
frankh's Avatar
frankh frankh is offline
Default yup 12V
24V makes a lot of sense but the extra hassle really does not pay enough of a benefit to make it worthwhile
Old 01-02-2012, 08:29 PM
GusBiz's Avatar
GusBiz GusBiz is offline
Default Weight
Its about weight mainly, that's not the only consideration but it's what the main argument is about. 24v allows you to use thinner wire. So it is less mass, but the battery is alot heavier. What does that all mean in the end? Well for a small plane where wire does not fun for 10s of metres, small batteries and thicker wire is better.
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
Old 01-03-2012, 09:33 AM
airguy's Avatar
airguy airguy is online now
The next major consideration (perhaps primary for some of us) is the price. Almost universally, where there is a price difference, 24-volt components are more expensive.
Old 01-03-2012, 10:04 AM
frankh's Avatar
Default Price
Try buying a 24V alternator from Autozone!...
Old 01-03-2012, 12:19 PM
John Clark's Avatar
John Clark John Clark is offline
In a small aircraft the weight issue is not worth the cost increase. I owned a 24v Baron for many years and the difference in price for things as basic as light bulbs was breathtaking, not to mention batteries, alternators, regulators and starters.
John Clark ATP, CFI
FAAST Team Representative
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 01-03-2012, 12:29 PM
airguy's Avatar
"Ummm, yeah, I think it's a Suzuki Samurai..."
Old 01-03-2012, 01:22 PM
Loboflyer Loboflyer is offline
Before putting all your faith in that document, consider the alternative viewpoint from Bob Nuckolls:
http://www.aeroelectric.com/articles...r/richter.html
Make sure to read the pdf files linked as first and second pass reviews.
Note: I am not saying that Bob is more right than Greg, but one should always consider both sides to every story.
-Jeff B.-
Albuquerque, NM
RV-7A (Preview Plans Stage), VAF# 1149
Assisting/designing panel for flying RV-6A
Old 01-04-2012, 06:34 AM
N395V's Avatar
N395V N395V is offline
Has anyone ever calculated exactly how much weight would be saved in a typical RV by going to 28V as opposed to 14 V?
I gotta believe it is so insignificant as to be un-measurable.
Ultimately you are going to want to put something into the plane that is 14 v and not available in 28V. Now you add a converter, weight, and complexity.
Simple and cheap are better.
Milt Concannon
