Go Back   VAF Forums > Model Specific > RV-9/9A
Old 01-01-2012, 10:53 AM
kai kai is offline
Default Flap motor - current draw
Hi,
I?m just planning a complete rewiring and modification of the electrical and avionics system of our used RV-9A.
For that I have to do a load analysis for the electrical system.
Can anyone tell me the current draw of the flap motor?
Thanks!
Old 01-01-2012, 11:36 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Offhand, I can't tell you the current draw but I use a 7.5A breaker for my flaps and it's worked fine for 3+ years. I'm sure I researched the correct breaker before I installed it.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 01-01-2012, 05:46 PM
Wayne Gillispie Wayne Gillispie is offline
I think 3.5 Amps is what I came up with during a test with simulated air load. I have a 5A ATO fuse on it with 22.4 hours problem free.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 01-02-2012, 03:09 AM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
You can search the forums to find some interesting threads about flap motor current draw.
This one was quite interesting and might help you.
Happy New Year
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 01-02-2012, 08:51 AM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Planned for 7.5a
While 5a seems to work for most, I also simulated, and would get 3.5-3.8a running loaded (depending on temp) but would occasionally see 4.5a on startup loaded (one down position to next downward position). I went 7.5a and wired accordingly. I'm using the direct acting switch supplied with the kit.
Other threads noted have discussions re: issues at 5a long-term.
Remember, a CB is a shunt(thermally triggered), a shunt is essentially a resistor in series with your circuit. If you can size up, voltage drop across the CB at the same amperage is nominally less. If it matters, I dunno, but good practice and all of that.
Rick 90432
Old 01-02-2012, 11:52 AM
kai kai is offline
Thanks to all for the infos, that helps!
I think 5A is too small. Normally you should limit a CB at 80%. So that you should calculate with 4A max. When the amps go to 4.5 during motor start and then down to 3.5 to 3.8 it is a little bit too small. I will take a 7.5A CB and a AWG16 wire. That should be ok.
We have enough power in our RV. We will remove the 35A Alternator and install a 60A.
Happy new year from germany,
Kai.
Old 01-02-2012, 11:59 AM
islandmonkey's Avatar
islandmonkey islandmonkey is offline
Kai.
Welcome to VAF Kai. I have just noticed this is your second post on the Forum.
Frohes Neues Jahr aus der Schweiz!
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
Old 01-02-2012, 12:15 PM
AltonD's Avatar
AltonD AltonD is offline
Several threads out there where the 5 amp breakers occasionally tripped. Replaced with the 7.5 amp and problem solved. 180 hours and no issues with the 7.5 amp breaker.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 01-02-2012, 12:32 PM
kai kai is offline
@Anthony
Thank you very much. Yes, I?m new to the forum, we just bought a used RV-9A in the US and we will start to modify it. I?m sure i will post a lot more...
Und dir auch ein fr?hliches neues Jahr!
