Old 01-01-2012, 02:04 AM
Jonathan Cude's Avatar
Jonathan Cude Jonathan Cude is offline
Default Skyview Arinc429 offline
I just updated the software on my Skyview system to the latest release (3.2.2 I believe) and my Arinc adapter is no longer showing up on the network or blinking its red light.
I've switched network cables to the adapter with no luck.
Anyone have this issue? What am I missing?
Jonathan Cude
EAA 980 Fearless President
Mechanical and Aerospace Engineer
SedanFloral.com
RV-7A :: Penn Yan XS-IO-360 :: Tip-Up :: SkyView
Old 01-01-2012, 08:35 AM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Is the red light solid on or solid off?
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 01-01-2012, 08:50 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Happy new year
Hmmmmm it is Sunday, it is a holiday, New Years day, and it is way too early for a normal business to be open.
Yet here is a response from a factory representative.
Good customer service Dynon, and applause for Doug for creating this site also.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-01-2012, 09:20 AM
chipf chipf is offline
For what it's worth, my system updated with no problems. If you have two screens, you need to update both before all the network devices are fully working.
Chip Freitag
RV-9A N207LT
680 hrs
cfrv9aproject.blogspot
Old 01-01-2012, 03:05 PM
Red light appears to be off.. No blinking at all.
Jonathan Cude
SedanFloral.com
Old 01-01-2012, 07:25 PM
Hmm, an OFF led is a new one. A stuck on LED can indicate a bad software load. But an OFF led almost means no power or a very low level hardware failure.
If you can, your best test is to hook only the 429 module up to your screen with the test cable that comes with every screen. If the LED is still off and the network won't detect it, you have a failure, but I don't think it has anything to do with the software update. If that fixes it, then you have a wiring issue or a more complex software issue.
Dynon Avionics
425-402-0433
Old 01-21-2012, 03:04 PM
Upon closer inspection, the little led is on....no blinking. My attach bracket and cable was covering most of the led!
My jump dive was being weird on my computer... Do I just re install software?
Edit: Looks like reloading firmware is not possible??
Anyone else been down this road?
Jonathan Cude
SedanFloral.com
