Old 12-28-2011, 07:44 AM
pierre smith's Avatar
Default iPad question
Which nav program are you using in the iPad? I don't recognize it.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 12-28-2011, 09:59 AM
RudiGreyling's Avatar
RudiGreyling RudiGreyling is offline
Hi Pierre, i am Alpha testing it for a local guy, he most probably will release it early in the new year. So I cant say too much at this stage, but it will be irrelevant for non South Africans. We battle in South Africa with decent aviation maps and aps on the ipad, he saw the gap and took it. I am just helping to sort out the bugs...maybe if it is really successfull will he expand but i am speculating...
Rudi
Rudi Greyling, South Africa, RV 'ZULU 7' Flying & RV 'ZULU 10' Flying
"Science, freedom, beauty, adventure...what more could you ask of life? Aviation offers it all" - Charles A. Lindbergh
Old 12-28-2011, 02:27 PM
charger81 charger81 is offline
Default Why do I think.....
That if South Africa ever develops a Space Program, Rudi will be involved in some form or fashion?
Honestly Rudy, I get a kick out seeing what you do and in the time that it takes to do it. Truly inspiring in what you build and the quality associated with it.
Mike
Old 12-28-2011, 05:24 PM
Strasnuts Strasnuts is offline
Nice work Rudi! Love seeing the layout and innovation.
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 12-31-2011, 04:33 PM
jtrollin jtrollin is offline
Default So started to put things in my panel today
I still need to add some backup instruments to the right of my screens. The hole in the radio stack is for my yet purchased GTN 750.
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Last edited by jtrollin : 12-31-2011 at 04:44 PM. Reason: image size was way to big
Old 12-31-2011, 04:39 PM
Got2Fly's Avatar
Got2Fly Got2Fly is offline
Default Thanks for posting!
I'm truly thankful for all of you who post these pictures of you panels as they are inspiring. However, for the first time today, browsing through them a fear came over me because I saw all the wiring behind the panel in one picture. I know I'll figure it out when I get there, but man it looks like a daunting task to get a panel that looks as good as what you all are posting! Really makes me appreciate the handiwork.
Ken
RV-10 Empenage
Old 12-31-2011, 06:05 PM
rleffler's Avatar
rleffler rleffler is offline
Ken
RV-10 Empenage
Ken,
Like everything else with building a RV-10, start at step 1 and then move on to step 2. If you dwell on the fact that there are thousands of steps, it's easy to get overwhelmed. Wiring is the same way. Start with your schematic and check of each wire as you run it. You'll find that you'll be done shortly.
One process that I highly recommend is to NOT rivet the Upper Fuselage Assembly when the plans call for it. It can be riveted way later. I set mine on the dining room table upside down to wire my harness. It made working on the harness very easy.
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-01-2012, 05:59 AM
Default Yep
I echo Bob's advice...my building buddy on the -6A was petrified about wiring. I asked him one day, "Didn't your dad build houses for a living?"...."one brick at a time, no?"
He never again fretted the wiring...it all eventually worked and the smoke stayed in the wires!
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 01-02-2012, 02:01 PM
RNewman RNewman is offline
Default N541RV is almost ready to go.
3 screen AFS system (two 4500's, one 3400 mfd)
AFS Pilot (tru-trak) autopilot
Dual GNS-430 W
PS eng audio panel
327 transponder
Fiberglass panel started life from Accuracy Avionics of many years ago but was completely reworked, added black powder coated aluminum masks that cover most of the instrument screws.
And of course, a full suite of TCW gear hidden behind the scenes.
Bob Newman
40176
RCNewmanJr.
Old 01-02-2012, 07:28 PM
Thumbs up
Nice Bob! Love the fit and finish. The glare shield lip looks great too.
