12-16-2011, 04:45 PM
Electronic ignition
Which plugs to use with and electronic ignition, aviation or automotive???
Any suggestions will be appreciated
12-16-2011, 04:56 PM
Senior Curmudgeon
What system??
My Slick LASAR electronic ignition uses standard aviation plugs.
Other electronic ignitions use auto plugs.
Most of the electronic ignitions I know of use a plug gap of .035" or so, and thus auto plugs work well.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-16-2011, 05:38 PM
Automotive NGK Uridium Plugs, gap will depend on compression ratio.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
12-17-2011, 05:05 AM
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
12-25-2011, 05:05 PM
4 for 6 bucks!
I have been using a single EI and Mag setup on my RV's since Jeff Rose built the first true system back in the 90's. My current RVX has a Jeff Rose Electroair system and I chose to use Automotive plugs, no adapters and Accel plug wires. Adapting the EI automotive plug wires to aircraft plugs can present some challenges. For me though, it boiled down to cost. I have been running them nearly 3000 hours in previous and current airplanes, no worries.
I replace the auto plugs every inspection, $6.95 at Napa. I use either Autolite 386's or Denso L-14U plugs(18MM). Worked in my IO-540 powered Rocket and my 0-320 powered X, the same. Clean, plentiful, easily accessible and cheap.
Smokey
12-25-2011, 08:57 PM
Automotive plugs and no adaptors?
Smokey
Can this be true??
Frank
12-26-2011, 05:03 AM
Smokey
The "new" Jeff Rose ignition systems - aka Electroair - recommend using REM37BY aircraft plugs, even for their experimental systems.
http://www.electroair.net/pdf/Installation-Manual.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
12-26-2011, 06:10 AM
VAF Moderator
I agree with Gil. I run the 37BY plugs using a standard .016 gap with great success.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993 SOLD
12-26-2011, 12:27 PM
When I replaced my previous EI with an ElectroAir EI a couple years ago, Mike at EA asked if I wanted to go with auto or aircraft plugs. I asked what he recommended, and he said Aircraft. He said he likes REM37BY because they are easy to gap (due to the electrode design)...so I went with his recommendation. As Gil mentioned, that is reflected in their install manual as well.
Not sure if the aircraft plug recommendation is related to their efforts to get the system certificated (which it may now be...haven't kept up with that), but Mike did say either (auto or aircraft) works great.
I started with REM37BY on the EI and REM38E on the mag, then just went all REM37BY, for commonality of spare parts, etc. I gap the mag plugs to .016 and the EI plugs to .030-.035. Seems to be working quite well!
Smokey's system works great, and ya can't argue with the costs! I've been happy with the performance and reliability of my EA system as well, so looks like we have a nice set of options!!
Bob
12-26-2011, 07:55 PM
I have a Plasma III and a mag and I use Denso IK27's on the elecronic side and have had excellent service from them. They cost less than 6 bucks each and I replace them at every annual. My mag side uses UREM40E's and they look good too, but cost a lot more. I tried some iridium plugs one year and they worked fine, but cost 3X as much. They are made to last a long time, and I don't need that. The standard Denso's will easily last a year, even if you fly 200 hours, and then you throw them away. My Unisom plugs last a long time and I clean and gap them every year, but installing new plugs on the electronic side is sure quick and easy.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
