Old 12-23-2011, 07:41 AM
Phil's Avatar
Phil Phil is offline
Default Removing the seats
Has anyone devised a modification that will allow the seats to be installed and removed without having to unbolt the T-handle every time?
Just curious.
Phil
Old 12-23-2011, 10:43 AM
Rick S. Rick S. is offline
No, but I did put nutplates in so it makes easier to remove the handles. Also removing about an inch or so off the back of the rail lip allows you to remove the seat without removing the flap torq rod cover.
Rick Sked
Old 12-23-2011, 10:49 AM
rleffler's Avatar
rleffler rleffler is offline
I haven't heard that you had to unbolt the t-handle before. So I'm in for a surprize when I install my seats after the holidays?
I am planning to install a t-handle mod designed by Greg, but it's waiting for my seats to get back from Geoff at the moment. This solves the problem that Pierre acurately described in another thread about having fat fingers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-23-2011, 11:18 AM
N427EF N427EF is offline
Default No nut plates!
Phil,
Spare yourself the trouble of installing nutplates.
I did install them and after having extreme difficulty getting a bolt started
into a nut plate I removed them again.
Once all your sidepanels are in you only have about an inch and a half in a very awkward place to get that bolt started and it is much easier if you can stick the bolt through and start the nut on the inside of the seat.
Now, if you could install nut plates on the outside that would make things easier. Having the extended handle helps as this allows you to partially insert the bolts and lower the assembly into place then push all the bolts in and
thread the nuts on on the inside.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 12-23-2011, 12:05 PM
Phil's Avatar
Yeah Bob.
If you look at your rails (the side that the T-handle travels on) you will see there are forward and aft safety stops to keep the seat from sliding off the front or rear of the rail.
The frame of the T-Handle hits those stops. So you have to remove the T-handle, install the seat, then re-install the T-handle when it's between the stops. It's not that big of a deal, just a little annoying.
Rick S...... LONG TIME NO HEAR!!
I hadn't heard of interference with the flap rod covers. That's good to know.
Old 12-23-2011, 12:16 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
It is in the archives, bout a year and a half ago, maybe a bit longer.
Good thread, includes good photos.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-23-2011, 12:17 PM
N15JB N15JB is offline
I have the T handle extension that Bob pictured and really like them, but it is still necessary to remove the T handle plate to remove the seat. I tapped threads in the plate so that I could eliminate the nuts. That way the bolts go in from inside the seat frame. As Pierre would say, easy peasy.
Jim Berry
RV-10
Off to GLO in 10 days for a slick paint job, finally
Old 12-23-2011, 02:15 PM
TSwezey TSwezey is offline
It gets pretty easy to do after you have done it twenty times or so.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 12-23-2011, 03:12 PM
Wayne Gillispie Wayne Gillispie is offline
No need to install seat, t-handle or flap tube cover until ready for first flight. I just sat on cushions for avionics setup. I will be removing them once a year. The std t-handle is fine unless you have an interior or 1"> fingers.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 12-23-2011, 03:41 PM
Default Tap threads into handle
Jim's idea makes the most sense if you want easy removal and installation.
The idea crossed my mind but then I started to over think the whole
installation and settled for the factory suggested method.
Ernst Freitag
