12-21-2011, 12:23 AM
Garmin 696/796 amp draw.
I'm doing a power load analysis and I would appreciate it if any-one with a Garmin 696 or 796 can advise me how many amps the device consumes in continuous operation.
Bob Barrow
RV7A
12-21-2011, 05:41 AM
I have my 696 on a 1 amp fuse and it's never "blown", did not see a spec on it in the manual.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
12-21-2011, 09:26 AM
From my final load plan sheets...
I show .4 amp in my final load VP-50 planning sheets...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
12-21-2011, 01:55 PM
I think that 4 amps is in there somewhere....
Dave & Trina
RV-9A Flying  - 330 Hrs. Painted  Finishing the interior.
12-22-2011, 08:39 PM
The 796 hard wiring harness comes with a 3 amp fuse installed in it.
12-22-2011, 09:26 PM
Mine is 1.7 amps
That is with XM running and steady state like you would typically see in flight. I did not measure boot up. Bat was about 2/3 charged and some of that current would have been charging the battery. It is a 696
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Reason: Add info
12-23-2011, 06:20 AM
Mine draws about 0.6A with the screen at full brightness, without XM.
Tom Costanza
RV-7A Fuse
09-15-2013, 09:42 AM
696 Power Draw
Just for reference, I had my VPX configured for a 2 amp draw for the 696 and it would trip every time. Setting it to 3 amps (which required a pin reassignment) and will let you know if it was successful. At least now, that circuit can draw up to 5 amps so it will be just a software change if it does not work, as opposed to assigning a different pin.
09-15-2013, 11:24 AM
The 795 has a 3A inline fuse. When it's internal battery needs a small amount of charging and the unit is operating at full brightness, I see 1.7A pretty consistently.
09-16-2013, 01:29 PM
updates
Upon further investigation, the 696 was on a 1 amp circuit that I moved to a max 5 amp circuit that is set at 3 amps. I am sure it will not have any problems and was probable drawing just over 1 amp when it would trip (charging the battery).
