Old 11-29-2011, 12:47 PM
longez360 longez360 is offline
Default Aerovoltz Lithium-ion battery
Hi All, I am interested in the application of lithiun-ion battery technology to my aircraft to reduce weight. The availability of the Aerovoltz 16 cell (available from from Aircraft Spruce and other aviation suppliers - link below) would cut my 15.4lbs Odyssey PC680 battery weight to 3lbs total.................
http://www.aircraftspruce.com/catalo...aerovoltz4.php
A supplier (Leading Edge Airfoils) has stated:
"Yes. The battery is a drop in replacement and will work well with the aircraft charging system.* I would strongly recommend purchasing the Aerovoltz battery charger for ground charging. It is quite different than that of a lead acid battery charger and will greatly extend the life of the bettery."
Does anyone have any experience with this specific battery system in an aircraft? I cannot find any specification or contact information on the Aerovoltz website to quiz their engineers.
I have read most of the non-specific/unrelated lithium ion battery horror stories on the net and would prefer to avoid descending into that discussion, but rather keep this thread more specific.
Cheers
Wayne Blackler
Long EZ O-360
AUSTRALIA
Old 11-29-2011, 01:26 PM
Ironflight's Avatar
VAF Moderator / Line Boy
This looks suspicously like the Lithium Iron batteries that I have been looking at:
http://www.ballisticparts.com/index.php
I am guessing that there are a number of companies marketing the same product at the retail level. They look quite promising!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-29-2011, 01:35 PM
DCat22's Avatar
DCat22 DCat22 is offline
Exact same price and the same marketing bullets....I'd say we have a match.
It is interesting stuff. I was considering trying a small one out for another project...haven't heard any feedback elsewhere yet.
One thing I saw on another site:
"Does the BALLISTIC PERFORMANCE COMPONENT Battery work well with a constant draw?
The current product has been designed and developed as a starter battery in a powersports application. If there is a parasitic draw on your powersports vehicle (such as an alarm) we recommend that you disconnect the battery when not in use. If the battery is completely drained the cells can be damaged.
And looks like a little more fall off in below freezing weather: http://www.ballisticparts.com/tech/faq.php
Not nay-saying...just looking for things to be aware of.
PS. Amazon has them for $239 and free shipping. http://www.amazon.com/PERFORMANCE-16.../dp/B005C5XS2U (Not the aviation branded one...no idea if there is any difference.)
-Rick Greer, VAF #2492
Old 11-29-2011, 02:17 PM
RVadmirer RVadmirer is offline
The canard forums are discussing too. Seems there have been some fires in commercial applications.....? One battery guru suggested waiting a couple years, may have been an old comment. Hope so, they seem to be very light.
http://www.ainonline.com/?q=aviation...eign-batteries
Wish this was dated:
http://www.mpoweruk.com/lithium_failures.htm
Old 11-29-2011, 05:07 PM
Some more info:
Wayne, thank you for the call yesterday, our lithium iron phosphate batteries are compatible with the 12 volt charging systems. *We do not currently have a BMS system in the battery due to cranking amp restrictions and cost to build a custom one. Our larger 1000cca batteries have them but sell for around 1000.00 us.
I have several of the larger plane builders now offering our battery as an OEM upgrade with the Kitfox brand, Titan, mosquito helicopters, and a long list of folks out field testing like Cub Crafters, Pipistrel and a few others.
We have ceramic heat shields built into the cases and we have passed all of the UNDOT testing standards for safety.
I do offer a balance charger and the batteries have a balance port built in for optimum charging and service life. *
Please let me know if you have any questions or need specific information.
Kind regards
Steve Johnson
Everything Aero
Sent from my iPad
Old 11-29-2011, 07:33 PM
kevinh's Avatar
kevinh kevinh is offline
Exclamation
At my 'day job' I work as a software engineer at an electric vehicle company. Li-ion packs could eventually be great for airplanes, but until vendor X has integrated BMS (a little computer that constantly monitors battery health and performs needed balancing) I would stay away.
Li-ion packs can generate big fires very quickly (I've seen it first hand).
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 11-29-2011, 07:37 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Originally Posted by kevinh View Post
At my 'day job' I work as a software engineer at an electric vehicle company...
The breadth of knowledge on this forum is continually astounding to me.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 11-29-2011, 07:56 PM
DCat22's Avatar
Are these "Lithium Iron Phosphate" and "Lithium Ion" the same thing?
Old 11-29-2011, 08:03 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
http://electronics.howstuffworks.com...n-battery2.htm
If the short lifetime and death if they are discharged apply to this battery I would not use it even if the fire issue is not an issue.
Old 11-29-2011, 08:16 PM
kevinh's Avatar
I don't know what chemistry these packs are using but LFPs (lithium iron phosphate) batteries are different from lithium ion batteries (typically involving cobalt).
LFP cells are safer than most Li-ion (or Li-po) batteries, but I still wouldn't want to use them without a BMS.
Besides preventing fires, BMSes also keep you from draining your battery too low or overcharging.
