Old 11-24-2011, 09:00 PM
Alschief Alschief is offline
Default RV-12 Tie Down
Where are the tie down locations located for the RV-12?
AL & Brenda Smith
RV12, UL Power N495BA Flying
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 11-24-2011, 10:10 PM
crashley crashley is offline
Default tiedowns
middle of wing underside and at rear of tail they are removable screw in eyes
Old 11-25-2011, 07:49 AM
JoeM's Avatar
JoeM JoeM is offline
Would it be acceptable to use the wingtip handles to tie down?
Joe Mikus
MSgt USAF Ret Avionics Tech
Perryville, MD
Student Sport Pilot
Future RV-12 Builder?
Old 11-25-2011, 08:23 AM
vernhendershott vernhendershott is offline
Hi Joe,
The wing tie-downs are very strongly attached to the front spar to take the load, the wing tip handles were designed to allow you to hold about 50 pounds (the maximum weight you will see at that end of the wing) when handling the wing, they work just fine as hand holds but would not take the load of the aircraft trying to fly while tied down. It is a very simple thing to screw in the tie-down rings when you tie it down.
Best regards,
Vern
Old 11-25-2011, 09:34 AM
DHeal DHeal is offline
There is also a loop welded to the lower portion of the nose gear leg that can also be used for tie down purposes. The presence of a nose wheel pant makes such use somewhat problematic, but you could still "triangulate" some kind of tie down rope/spike arranagement if the winds were forecast to really howl. David
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 11-25-2011, 05:22 PM
Default Tie Down
What drawing shows the tie down?
We did not build the wings. We do not have a hole where the tie dowen should be attached
AL & Brenda Smith
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 11-25-2011, 05:25 PM
rgmwa rgmwa is offline
13-02 and 17-02 (step 3 and Fig 2). Should be an easy fix.
rgmwa
RV-12LR 912ULS
120346
Old 11-25-2011, 06:09 PM
ChuckC ChuckC is offline
If you look at the top of the wings, you will find a small hole just opposite of where the tie downs go on the bottom of the wings. If you ever need a crane to lift your 12 straight up (for loading on a barge for example), you can drill out these holes in the top of the wings, insert 3/8" eye-bolts and attach a lifting cradle to the eye-bolts. Learned this little tidbit on a recent visit to the factory. They are always thinking ahead.
Chuck Carlson
120445
Old 11-25-2011, 07:09 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
Unless you are going EAB. For the ELSA people, you are supposed to drill out the top wing "tiedowns" as well as the bottom. I am looking for some sort of machine gun or rocket fixtures to fill the holes with.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 11-25-2011, 07:23 PM
Tony_T's Avatar
Tony_T Tony_T is offline
There is the (maybe remote) possiblilty that the builder did not tap the holes for the tie downs. Why would they not open the access holes?
Tony
E-LSA RV-12 ULS
