Old 11-18-2011, 11:02 AM
MirokHakusho MirokHakusho is offline
Default Marker Beacon Antenna
Hello,
I need a little help about the MB installation location.
I've a RV-10 with a lot of antennas e I don't know where I should install the MB antenna.
Follow pictures of the antennas location below
And has another RSM on the top cabin.
Someone here have any idea?
Higor
Old 11-18-2011, 12:06 PM
johngoodman's Avatar
johngoodman johngoodman is offline
Look into an Archer antenna in the wingtip.
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 11-18-2011, 01:32 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
I'll start with "on the bottom"
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 11-18-2011, 04:13 PM
9GT's Avatar
9GT 9GT is offline
I put mine in the fiberglass wing tip.
David C.
Howell, MI
Old 11-18-2011, 04:29 PM
flion's Avatar
flion flion is offline
I put a standard antenna under the systems bay just forward of the spar. Here's my builder log entry link with pictures.
EAA Technical Counselor #5357
Old 11-18-2011, 05:33 PM
flyinga flyinga is offline
Why on Earth do you want a marker beacon, assuming you have an IFR GPS?
Old 11-18-2011, 06:05 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Many foreign countries have different rules than the U.S. (take a look at the OP's location). We sold a perfectly serviceable (and more less useless to us) ADF to an RVator in Italy who was required to have one to be IFR. It's a big world....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-21-2011, 04:13 AM
Thank you all.
I think the wingtip is the best place.
Does anyone have a photo of the antenna installed in wingtip on RV-10??
It's a customer wish, I only install.
Higor
Old 11-21-2011, 06:48 AM
flion's Avatar
No photo, but it's not a big deal. I have the Archer in my RV-6A. His directions are easy to follow. I laid 6oz. glass (from a R/C hobby shop) over the antenna strip after it was installed to protect it. Run your coax separately from the lighting runs. That's about it.
Old 11-21-2011, 07:29 AM
Wayne Gillispie Wayne Gillispie is offline
I just completed mine in the tip as many have done. Coax from audio panel to tip rib with bulkhead bnc fitting. Take approx 55" of coax, strip off 40" of shield leaving separator/insulation on center conductor. Install bnc conn on other end. Temporarily tape and ensure you have a little extra to make tip removal/installation easier. Then apply one layer of fg to hold in place. Run antenna fore-aft as far from alum rib as possible on bottom side of fairing.
Good judgment comes from experience, and a lot of that comes from bad judgment.
