Old 11-17-2011, 08:05 AM
AeroDog AeroDog is offline
Location: New London, NC (near Charlotte), Longmont, CO
Default To prime or not to prime (or what to prime), that is the question.
I've read every post I can find regarding priming, but I'm still conflicted. Opinions seem to range from "prime every surface" to "prime only what's absolutely necessary." Even regarding mating surfaces with dissimilar metals (galvanic corrosion), there's no concensus.
At one point I found an article (which I can no longer find -- I have a hard time navigating the official site) on Van's site espousing the minimalist approch, pointing out the lack of primer on the interior of Cessnas, Pipers and such.
If some long-time builder could point this newbie in the direction of a definitive article on this, I'd appreciate it.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete, engine ordered.
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2020
Old 11-17-2011, 08:15 AM
Mich48041 Mich48041 is offline
Only a chemist knows the answer and even she might answer, "It depends."
Joe Gores
Old 11-17-2011, 08:29 AM
Don's Avatar
Don Don is offline
I primed the 9A I'm building (using the NAPA self-etching primer). If I do another plane, I doubt that I prime it. At most I'd do the few parts that are not alclad and the ferrous parts.
Having said this, you are not going to get a definitive answer because the decision is subjective. Corrosion happens slowly. It's not going to turn your plane to a white powder while you're flying. It will corrode faster near salt water than it will inland. If you see corrosion there are products to treat it. Odds are it won't be needed. That's my subjective opinion after owning a 1974 Cherokee that's unprimed (mostly) for better than 10 years.
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 11-17-2011, 08:40 AM
Bill_H's Avatar
Bill_H Bill_H is offline
I feel your pain. I am another first time builder that did the same frustrating research that you did. What I decided was that if the interior parts of 50-year-old Pipers and Cessnas were not primed and had no issues, that is pretty compelling.
I looked at a BUNCH of builder logs. I have great respect for the total-primers - who mix 2-part primers and use spray guns (and then have to clean them after every use). To do that requires a lot of time, and also a lot of planning and construction delay to have reasonably sized batches. I did not see that kind of effort to be needed. To each his own, you are building the plane YOU want!
I found rattle-can self-etching aluminum primer to be a good choice. About $6 at Home Depot, Marhyde was about $15 a can at O'Reilly Auto.
I decided to prime the parts (scuff with scotchbright pad first) that were associated with the bottom of the plane. That included the inside of the bottom skin but not the fuselage ribs. Although I did prime the tailcone ribs, they were easy. I primed all small parts that were exposed and not fully enclosed - things like the rear spar of the vertical stabilizer, hinges, etc. Obviously, the tail's rear bulkhead. If it was small, connected, and easy to do I primed it. Wing ribs and interior stuff like that? No. I was probably not totally consistent in my choices!!!
Although, it turned out later that some of these choices would be primed again in the painting process. Sometimes that is tough to visualize early in the building process. (For my full painting description, see this thread:
http://www.vansairforce.com/communit...ad.php?t=67760
For some photos (not a builders log, just some quick sequential photos of the build which does show some painting info - easy to go through in 5 or 10 minutes) see here:
http://www.facebook.com/media/set/?s...1&l=a2b29e894a
Hope this is useful. This is a long - standing controversy and your final opinion will be as good as anyone elses!
And if anyone is a fan of sci-fi and particularly robots, see these pics I took at The Robot Hut!
http://www.facebook.com/media/set/?s...1&l=87a25084c8
Old 11-17-2011, 09:40 AM
Sam Buchanan's Avatar
been here awhile
Jerre
In fifteen years of being part of the RV community, I have never seen a definitive article on this subject. I doubt one has been authored.
My personal thoughts about priming circa 1997 are here. I've found no reason to change them since then.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 11-17-2011, 09:49 AM
Danny7 Danny7 is offline
prime the non al clad and get on to building
nothing special here...
Old 11-17-2011, 01:21 PM
bruceh's Avatar
bruceh bruceh is offline
I primed everything. Cost was about $500 (2 part epoxy, HVLP, supplies, etc.)
I didn't want to miss out on the experience
Now that I've done it, if I were to build again I would skip priming.
It does add time to the build (not a big deal for a slow build), it does add weight, and it isn't necessarily environmentally friendly. Like others have said, the alclad provides plenty of corrosion resistance and any problems will be years/decades down the line.
Bruce Hill
2020 VAF donator
Old 11-17-2011, 01:27 PM
RV8R999 RV8R999 is offline
I built a BD-4 (all alum) and sold it to pay for the -8. Ended up reducing the price substantially because of discovered corrosion on several wing ribs and skins which required significant repair, not to mention the questions about other less easy to inspect areas all potential buyers asked about.
Because of this experience I chose to prime EVERTHING (2 part epoxy) and was still able to complete the slow build (including prime and paint) in just over 21 months start to first flight.
YMMV
Old 11-17-2011, 03:41 PM
My mostly unpainted and unprimed 1955 Cessna has little corrosion. The catch is that it's always been an inland airplane, and all the corrosion it has came from being tied down outside for six months near Philadelphia.
Even hangared for nearly three years in Oxnard, CA (like three miles from the ocean) didn't do much damage. Those few months outside in PA sure did, though.
I suppose the moral is that if your plane is ever going to be kept within a hundred miles of a beach, prime it. Otherwise, don't. And if you do, try to be rigorous about saving weight elsewhere to compensate.
Incidentally, 6061-T6, although not alclad, has good resistance to corrosion. Some people don't prime that. In marine use, though, it's either anodized or painted or both. But that's in marine usage.
Dave
Old 11-17-2011, 04:34 PM
E. D. Eliot E. D. Eliot is offline
Default Me too
I am not disputing anything that anyone has written about not priming but I am leaning towards 'priming everything' inside. I have see the insides of a few of the C-152, C-172, PA-161s, etc which are based at a flying club a few miles away in Long Beach - they all have corrosion to one extent or another.
Wondering about seaplanes, etc - are they primed inside?
I live about 1/8 mile from the Pacific Ocean and gotta tell you, some types of bare steel begin to rust here in about a week. So, I think that priming everything inside might be a good idea.
Given the costs and waiting period of a hanger in these parts, my RV-12 will have to be left outside - OR, take it home after flying and put it away in the garage OR, I can base it in a hanger inland about one hour drive away.
Bringing it home on a trailer is done by so few (none?) of you that I am pretty sure that it isn't practical.
I own two cases of NAPA xxxx spray cans. Anyone want to buy them? Think that I'll switch to a two part primer/sealer and spray it on with an hvlp gun.
