Old 11-15-2011, 04:02 AM
brick brick is offline
Default RV Pitot
Hi guys!! I have purchased a Pitot tube bracket (for RV'S) from aircraft spruce.Its a bracket for a Falcon Heated Pitot. Of course it came with no mounting instructions Has anyone installed one of these? Am open to any suggestions which may be an appropriate mounting solution. Thanks in advance
Old 11-17-2011, 07:12 PM
Smilin' Jack Smilin' Jack is offline
On the Safe Air heated pitot tube it mounts in the next rib outboard from the alieron bellcrank. If you go to their web site you'll see that it has a flat plate welded to a mast. The flat plate is double bent to slip in behind the spar.
You can buy mast from aircraft spruce I would guest that the mast from Safe Air is approximately 5 inchs. long.
Smilin' Jack
[IMG][/IMG]
Old 11-17-2011, 08:43 PM
Thanks for the reply Jack!!!
