  #11
Old 11-13-2011, 08:08 PM
rvbuilder2002's Avatar
Originally Posted by David-aviator View Post
I know of a recent local first flight where a CFI accompanied the builder on the flight. Who is to say his presence was not "essential to the purpose of the flight"? From a safety and practical point of view most would agree it is OK.
David,
I strongly disagree with this statement.
I don't think most would agree it was ok.
I think most will say that if the builder needed a CFI in the plane to be safe, then a different test pilot needed to be making the first flight.
Old 11-13-2011, 08:13 PM
DanBaier's Avatar
DanBaier DanBaier is offline
"... Here is one vote for moving Vic's post to Best of the Best...."
Plus 1
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 11-13-2011, 08:41 PM
Originally Posted by vic syracuse View Post
Well, I hope I won't be banned for starting this thread, but quite candidly I am getting very annoyed with the flagrant rules violations occuring in 2 specific areas of our piece of the aviation world: obvious building for hire and multiple people in the aircraft during Phase I fly-off period. Most recently we have had another accident with people seriously hurt during Phase I. This stuff is impacting all of us, and unless we start policing ourselves, we are going to get help that we don't want or need.
<much good stuff snipped>
Vic
The sentiment among the people who do these things is "Nobody has gotten busted yet and I'm betting I won't be the first.". Historically, that's been a pretty good bet.
They also rationalize that others have done it, so why shouldn't they?
It's a bad situation and the community needs to address it.
If the FAA carried out a few high profile crucifictions, that might put the brakes on the build-for-hire types. However, the FAA couldn't hold the line effectively with Epic, so are they really gonna go after a guy churning out RV's? From a airworthiness certificate standpoint, how often do DAR's walk away from projects with a questionable build history? Even if they do, the community knows the DAR's who are comfortable winking at the rules as long as the check doesn't bounce.
On the violations during the test period, would it be appropriate for aircraft within the test period to carry large vinyl markings signifying that the aircraft is in Phase 1 and no pax are allowed? That would raise the ante a bit for violators...
As you stated, we need to address these issues. Otherwise, the Fed's are going to create new burdens for those of us who follow the rules. It won't be a problem for the rule breakers - they will ignore the new rules too...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-13-2011, 08:46 PM
Vic,
The problem lies within the rules governing what we do. It is not a clear black and white issue.
With regard to more than one person in the airplane during flight testing, my operating limitations state:
"During the flight-testing phase, no person may be carried in this aircraft during flight unless that person is essential to the purpose of the flight."
I don't see that anyone can make a legitimate case that a second person is/was necessary on a first flight of a single engine piston aircraft. The airplane doesn't require it, and it will never pass a sniff test.
If the pilot is incapable of handling the job by him/herself, that can be addressed through training or by having a more capable pilot make the flight. There is really no excuse.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-13-2011, 08:55 PM
Mel's Avatar
Mel Mel is offline
A DAR cannot legally "walk away". Once the application has been accepted, the DAR must either "issue or deny" the certificate. If the certificate is denied, an e-mail is immediately sent to all inspectors throughout the U.S. stating the reason for the denial. It would be up to the "next" inspector to determine whether the discrepancies are justified or corrected. It would be rare for another inspector to accept discrepancies that have already been denied on record.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-13-2011, 09:02 PM
plehrke's Avatar
plehrke plehrke is offline
Vic,
Mine says that as well.
Why does the DAR not just write the limitations to eliminate the second half of the statement? The DAR can make the determination that for that particular aircraft, only one crew is required for flight test. Therefore put
"During the flight-testing phase, no passenger may be carried in this aircraft during flight"
Of coarse someone will get around the rule and say they are not passengers but flight crew.
Philip
RV-6A - 14+ years, 950+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Mel's Avatar
Mel Mel is offline
Default The p
That leaves an awful lot of wiggle room on the issue. Has the FAA defined "essential to the purpose of the flight"? I don't think so.
The "purpose of the flight" is flight testing the aircraft, period! Not flight training or anything else.
This is NOT a gray area. The only time a second person is required for the purpose of the flight is when the AIRCRAFT requires a crew of 2 or more. None of our airplanes fall into this category.
How many denials were issued last year because the DAR didn't think the aircraft met the 51% rule?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 11-13-2011, 09:09 PM
Mel's Avatar
Mel Mel is offline
Actually the wording HAS changed within the Light-Sport op lims. They state that the pilot will be the sole occupant of the aircraft.
For amateur-built aircraft, unfortunately DARs cannot change the original wording of the op lims. They must be stated exactly as laid out in 8130.2. We are allowed to add limitations as we see fit in the interest of safety, but we can remove nothing.
Old 11-13-2011, 09:11 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
The second person in an RV during Phase 1 has been discussed before and I believe the consensus is that two pilots are NOT required.
