Old 11-11-2011, 10:44 AM
steve91t steve91t is offline
Default 155kt cruise?
Hey guys, I'm asking this question for my dad who owns a very nice RV7 with 180 hp and a 3 bladed CS prop. I can't remember who makes the prop. Anyway, it has an amazing climb but cruise at 2450 or so is right at 155 kts true at 8.5 gph.
How is it that I'm seeing guys with less power cruising at 165 kts? I know the 3 bladed prop will have a better climb than a 2 bladed, but the cruise is going to be a little slower. How much slower? I think it weighs around 1100 full IFR, glass panel.
I just wanted to see how some of you guys are getting faster cruise speeds. I know Smokey's RVX can cruise at 160 KTS easily. Of course that's a light, slippery little plane.
Here's a quick video of the plane starting up last month.
http://www.youtube.com/watch?v=9-x-2UTXuGE
Old 11-11-2011, 11:24 AM
Tandem46's Avatar
Tandem46 Tandem46 is offline
I've always got 170-172kts True above 8k on 8.5gph. That same 8.5gph down low only gives me 150-155kts true. I'm running IO-360 with CS prop. 1070lbs empty.
RV-7 Flying since 2004
1,100 hrs+
Old 11-11-2011, 11:30 AM
craigvince's Avatar
craigvince craigvince is offline
Question Yeah, my first thought too....
At what altitude are you cruising at 155 kts?
I can pretty consistently get 170kts at 12k, which is where I prefer to ride, but down low you're not going to see that. By the way, I've had an RV-7A at 17,200 feet but it would only do about 140kts TAS.
Old 11-11-2011, 11:32 AM
Sorry, this is 8000ft or so.
Old 11-11-2011, 11:35 AM
Bavafa Bavafa is offline
As it has been mentioned, it depends on a number of factors including to check to see if you have an accurate pitot/static setup to get a good IAS.
My typical TAS/burn rate is very much in line with the above posters.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 11-11-2011, 11:45 AM
Well, everything seems to match the GPS. We were at 9000 last month showing 155kts true. GPS said we had 7 kts on the tail, showing 162 across the ground.
What else could it be? From some of the comments he's gotten, especially from mechanics, it's one of the best built RV's they've seen. It's rigged perfectly, and the engine runs flawlessly.
Is it the prop?
I mean, 15-18 kts is pretty substantial.
Steve
Old 11-11-2011, 11:55 AM
Just got clarification, 65% power, 2450 RPM in cruise at 8000 ft. The 155kt cruise matches Vans numbers if he were using 55% power.
Old 11-11-2011, 11:58 AM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
do a gps box to verify the speed. Then you know you have a power problem if the actual speed is verified low, or an indication problem if the actual speed is higher.
right now I am getting around 165kt cruise at around 8gph, 8000 da.
flat out 185kt at 3000 da, about 16gph.
I am looking for some missing manifold pressure from my snorkel. A winter project perhaps.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 11-11-2011, 12:13 PM
Engine is healthy. Just had an annual. If the engine is making proper MP, that means its developing the correct power, right? What is normal MP at 8000?
Old 11-11-2011, 12:15 PM
Also, I know a 3 bladed prop isn't going to have the cruise of a 2 bladed. How much of a difference though? His is a light weight composite. Company is out of Florida.
