  #31
Old 10-26-2011, 02:40 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
A short runway?
Is the one you have an "over run" on, the rest are long enough
Old 10-26-2011, 02:50 PM
luddite42 luddite42 is offline
Originally Posted by PerfTech View Post
I can consistently land my 9-A in less than 600 ft. Less than this and I get a little nervous with braking pressures required. Regards, Allan
See Video http://vimeo.com/18601468
That's good, but I might add that you have a lot of room to touch down significantly slower, based on your fairly flat pitch attitude at touchdown in the video.
Old 10-26-2011, 02:53 PM
PerfTech's Avatar
PerfTech PerfTech is offline
Originally Posted by newt View Post
It's cheating if you're initiating the flare before the start of the runway.
What's your distance after clearing a 50' obstacle on final?
- mark
I usually go under or around all those 50 footers
Old 10-26-2011, 04:22 PM
PerfTech's Avatar
Originally Posted by mkbreezy View Post
Hey Allan,
If you really want to practice, come to my strip, and try it with trees at both ends. Its a long way to SC, but we would love to have you. That goes for any RV'er that wants to try it.
Dantzler Plantation
N33 24.69
W080 30.3
You need to be careful what you say! I think I may just take you up on that invite! We are going to be back there in a few months and it would be nice to stop, meet you and talk airplane for a bit. Allan
Old 10-26-2011, 04:57 PM
mkbreezy's Avatar
mkbreezy mkbreezy is offline
Default Visit
Love to have you, take a look at dantzlerplantation.org, thats where we live. and the strip is right next to the house.
Mike Kullenberg
Dantzler Plantation
Providence, SC
RV-9A N409G
In paint at Glo-Custom new number is N573PM
ECI IO-360 CS
Dynon Skyview
Old 11-11-2011, 09:47 AM
David Fuchs David Fuchs is offline
Default Short Runway
CVT-16, The USS Lexington or The Lady Lex. 910'
(sorry) couldnt resist
Old 11-11-2011, 10:00 AM
mkjprice's Avatar
mkjprice mkjprice is offline
Default Not Short
But Fun - is X04 Orlando Apopka. It has been years since I flew into this airport, but it is a great airport to practice short and soft field landings. As you come in from the south, you get some awesome (or scary) visual illusions, which make it a challenge. I looks like they have done some improvments to it since I was there, because out 172 use to hang its tips over the side of the runway when we were there back in 2002. Now it is 60' wide and is nearly 4000' long, but it has a hump in the middle.
Mike Price
CFII/Multi Commercial
I'm gonna build me an RV one day soon
"The older I get -- the more I realize that sense is not common."
Old 11-11-2011, 10:52 AM
Phlyan Pan Phlyan Pan is offline
I did my first 15 hours in a 65hp champ on a 2200 ft grass strip with 50 ft trees off of the ends. With myself in an instructor on a hot day there was a bit of pucker factor on takeoff. Landings were never an issue.
Old 11-11-2011, 11:42 AM
mkbreezy's Avatar
Default Lady Lex
910 feet with no obstacles. Piece of cake even without arresting gear. I am routinely doing 7-8 hundred feet over 60 foot obstacles, and the takeoff is shorter than that. The 9's are truly great short field airplanes. (Anti Splat helps)
Mike Kullenberg
Dantzler Plantation
Providence, SC
RV-9A N409G
ECI IO-360 CS
Dynon Skyview
Old 11-11-2011, 12:33 PM
leaker311 leaker311 is offline
Default short
after landing...
Captain - Dang! a 150' long runway, whoever designed this thing must have been drunk at the time!!
Co-pilot - Absolutely!! look at the width of this thing!! It must be at least 8000' wide!!
