For the letters..
I used the 2/3 - 1/3 trick and it worked pretty well, though I used a helper to hold the 2/3 end instead of using shot bags.
For the bits in the middle of the letters & numbers - the little "islands" of wing-walk material.
Take the letters & numbers out before laying the wing-walk.
Leave the "islands" of wing walk in the R, the A and any numbers (e.g. 4, 6, 8,9)
Lay the wing walk.
Peel the backing off the "islands" - while leaving the island attached to the letter or number.
Put the letter back into its hole in the wing walk
Hold the "island" down while removing the letter from around it.
- that should leave you with the "island" of wing walk properly positioned in the middle of the letter or number.
Dave
Dave Boxall
RV-9A / Wilksch WAM-120 diesel. Flying since April 09
Bath England
=VAF= membership dues paid April 2017
