Old 10-16-2011, 07:48 AM
rgmwa rgmwa is offline
Default Section 35-03 update
Posted 12 Oct, but updated 10 May! You have to wonder why it takes Vans so long to post changes on the website.
http://vansaircraft.com/public/notices2.htm
rgmwa
RV-12LR 912ULS
120346
Old 10-16-2011, 09:58 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
OK, we need some attention to detail buffs in on this one. I ran off revision 2 and compared it to revision 1, after 15 minutes I have failed to find what (if anything) was changed! Has anyone else figured this out? Looks like Vans could tell us what changed, since I assembled mine to revision one, what do I have to do to update to revision 2?
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 10-16-2011, 01:20 PM
D&M Dan D&M Dan is offline
Default Bolt
Don,
Looks like the AN6-24 is changed to a AN6-23A
Old 10-16-2011, 03:16 PM
todehnal todehnal is offline
So, what did they send us; AN6-24's, AN6-24A's, or AN6-23A's??
The parts inventory says AN6-24's. I may have missed that minor detail on inventory, and I don't recall it being a drilled bolt, when I installed it.
Whatever was sent is installed and seemed to tighten up okay!
I'm sure that if this was really a problem, with our installation of the gear legs, we would have gotten a change notice, or, a mod to do.
I think that this is a "do nothing" item for us builders.
Tom
2013- RV12, Kit #119. N123M First flight Nov21. It's a keeper!
1998- RV-9 tail kit, built and sold
1989- RV-6 tail kit, built and sold
Old 10-16-2011, 07:36 PM
rsipp rsipp is offline
I certainly agree that if Van is going to the trouble of publishing a change, it is no more work to add the item changed note in sheet data block.
"Back in the day" when the plans were hand drawn by Van, changes were noted.
Dick Sipp
RV-4
RV-10
RV-12 mentor
Old 10-17-2011, 07:37 AM
I don't think the change is showing a drilled bolt. There is no cotter pin depicted and AN6-23A is avaliable undrilled. Mine is assembled and I don't see any reason to change it.
Old 10-17-2011, 01:26 PM
Default My Understanding
My Understanding is:
The "A" represents undrilled bolts.
The lack of the "A" means that it is a drilled bolt
Tom
Old 10-17-2011, 06:01 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
The original bolt in the plans was a drilled AN6. There was never a cotter pin that was installed. Must be a change to an "A" so there is no cotter pin needed. The other may have caused confusion as it was installed with a nylon locknut and no pin.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
