Old 09-30-2010, 07:15 PM
N53LW N53LW is offline
Default AWI 4 in 1 exhaust
Have the AWI 4 n 1 exhaust on the RV-8, was wondering if anyone else is having problems with the collecter cracking? Have 230 hrs on the plane and it has cracked 3 times so far. AWI has made us a new collector , it also has cracked. We have the exhaust supported ahead of the collector, but have no real solution for supporting the 4 n 1 collector itself. Any ideas would be appreciated. Thanks.
Old 09-30-2010, 07:30 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
I have about 200 hrs on this system with no problems. I supported the collector off the rear two bolts that connect the collector to the 4 pipes. I used a system similar to the Vetterman system. I will post pictures over the weekend.
I did cut the collector a little at the rear to get a more rearward opening. I also cut the two top pipes from the cylinders so that the collector would move up a little closer to the fuselage. Perhaps you are trying to pull it up toward the fuse and putting some stress on the system.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 09-30-2010, 09:15 PM
DanH's Avatar
DanH DanH is online now
Hmmm.....mine is supported aft of the pipe join, in the middle of the collector section, using cable loop hardware supplied by AWI. I really like the design. However, no flight time yet.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-12-2011, 05:54 PM
DanH's Avatar
Follow-up report...cracked collector here, 144 hours in service. One socket was splitting away from the collector body. The cracks seem to originate at the interior welding (the "cone" area). Don't think it has anything to do with the support method. AWI has made weld repairs; we'll see how it holds up.
Phil, had any further problems?
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-12-2011, 07:40 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default The single pipe setup...
begs the question. What is the advantage? Faster speed/lower drag, cost, esthetics?
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 10-13-2011, 06:15 AM
Adam Adam is offline
I have 240 hrs on mine and have no signs of any cracks! My exhaust is unsupported as that was the way the original company told me to install it.
Adam Silverstein
Technical Counselor Chapter 643
Flying RV-8 10/30/07
PAID 2021
Pittstown, New Jersey
Old 10-13-2011, 07:49 AM
DanH's Avatar
Look up inside the tailpipe. There was less than 1/2" of crack visible anywhere on the outside, probably 2-1/2" inside at the interior welds where all the pipes come together.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-13-2011, 08:54 AM
gnuse's Avatar
gnuse gnuse is offline
If you had ever heard a 4 into 1 you wouldn't be asking this question.
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 10-10-2013, 09:58 PM
Wicked Stick's Avatar
Wicked Stick Wicked Stick is offline
Default Cracked pipe between collector and heat muff area.
Today while performing my condition inspection, I found the following:
My RV-8 has 123 hours tach time on it.
Seems to me that since the other 3 pipes are fine, that this one might have been defective or mis-aligned when welded at the factory causing stress in that area. I have read others having collector issues, but thought I'd post this to see if anyone else has experienced an issue with theirs in this area.
Dave "WS" Rogers
RV-8 N173DR
Old 10-11-2013, 06:00 AM
DanH's Avatar
Dave, does that pipe bottom out in the collector socket, i.e. with the link disconnected you can't shove it in any further?
Dan Horton
RV-8 SS
Barrett IO-390
