10-11-2011, 04:47 AM
Team RV going to the dark side - need help
Team RV may be flying a night show next year!  We got some pretty neat HID lights to illuminate the smoke trail and figured out how to mount them on the belly. They will be removed for normal operations. What we can't find is a nice flush mounted, two prong electrical connector to provide power and ground to the light. It should be rated at 5+ amps and ideally would lock together with the plug and be weather resistant. Oh, and cheap!
Send me a link if you find something that might work. Thanks.
PS: Team RV is performing for the Boshears Skyfest at Daniel Field (KDNL) in Augusta, GA this weekend. Come and watch the show and drop by to say hello. We enjoy meeting the VAF pilots.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
10-11-2011, 04:53 AM
Ron, Did you not get enough night formation in the Military? Its dark out there at night and not as much lift. Not to mention just plain scary!!!
George
10-11-2011, 05:23 AM
Schedule
Ron, what time do y'all fly on Saturday?
RVRC
Robert Cutter
RC & Moonpie
RV7 slider - First flight 5/3/14
Over 500 hours on the Hobbs now
N516RC
10-11-2011, 06:06 AM
Ron, next time you are in 5W8, drop off the specs for the lights (volts/amps) and I will see what I can come up with. Just leave it in the FBO, or with Kimmy at Orion. Come to think of it, Kimmy may have a solution already with the work they (and you) do.
Is the team proposing to drill a hole in the belly somewhere and have the flush connector permanently mounted?
Seems like slot position will have to deal with headlights to the eyes...
10-11-2011, 07:16 AM
Noel,
The lights are 55 watt, 12 volt, 5 amp. The flush connector will be permanently mounted on the belly skin.
Yea, the slot position may be a little dicey. We have a lot a practicing to do!
Ron Schreck
IAC National Judge
VAF 2021 Donor
10-11-2011, 07:18 AM
Opening ceremonies are at 1:30 and we may be circling the flag jumper. Don't know our sequence in the lineup. Come watch the whole show!
Ron Schreck
IAC National Judge
VAF 2021 Donor
10-11-2011, 09:36 AM
Senior Curmudgeon
I think a trailer lighting connector would do just fine, they are rated for a lot more than 5 amps, and most of them have a spring loaded cover on the socket half for when it is not in use.
http://www.delcity.net/store/4!Conta...r/p_625907.a_1
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
10-11-2011, 11:37 AM
Simple and small
5 amps is the max on this series but
1) water proof cover
2) small flush mount
3) plug versions include one style with a locking ring
http://www.switchcraft.com/productsu...spx?Parent=957
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
10-11-2011, 11:43 AM
Senior Curmudgeon
http://www.wsdeans.com/products/plugs/ultra_plug.html
These carry a lot of amps, but you will need to create a mount of some kind.
Any hobby shop that caters to R/C will have them.
Small and light weight.
You could also mount a cigarette lighter socket in the belly, many of the after market ones have covers with them, for when the lights are not installed.
Many ways this feline can be skinned.
Mike Starkey
VAF 909
Rv-10, N210LM.
10-11-2011, 07:46 PM
Originally Posted by jdeas
OK, Jim. So far I'm liking this one best. Any others?
Ron Schreck
IAC National Judge
VAF 2021 Donor
