Old 10-03-2011, 10:47 AM
prporter prporter is offline
Originally Posted by Ron Lee View Post
I had 5 gallons last about eight months.
Ron- Did you make your own set-up?
Old 10-03-2011, 10:55 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default What system
Hey Andy,
Which smoke system are you running?
Originally Posted by Andy Hill View Post
As Bill says, none are cheap... However, there are 2 controls to limit the $$ - the on/off button, and the flow valve. Have a think why you really want it, and do you really need the full flow rate?
That said, the full rate can give impressive results:
Diesel works, but it needs higher flow rate to get same smoke effect, and your aircraft may well stink of it for a long time after The good smoke oils are essentially "baby oil", and smell/feel pleasant
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 10-03-2011, 11:01 AM
rvmills's Avatar
rvmills rvmills is offline
Originally Posted by mv031161 View Post
Cheapest way to go is concrete form oil.
Mitch, do you have a source for inexpensive/cheap concrete form release oil? I'd love a vector...much preferred stuff!
Thanks!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 10-03-2011, 12:19 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Smoking Airplanes system. 3.5 gallons. Two injectors.
I see you moved to Virginia.
Old 10-03-2011, 12:30 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
Hey Andy,
Both aircraft using SA-100 systems with twin injectors. Set up for ~2L/0.5USG / min.
Cheapest way to go is concrete form oil ... 1 galon a minute is the best economic setup... I have a 7 gallons system on mine and it gets used in 5 minutes
I don't know anything about 'concrete form oil ', but if that flow rate is required, it is over double what we use, and we would be unable to do a display as we currently do (would run out of smoke oil). We use "standard smoke oil" - types similar to Ondina - 2L/min is approx max which will burn (as per SA instructions, put any more in and you just get a baby oil covered tailwheel )
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
Old 10-03-2011, 07:28 PM
rvmills's Avatar
Andy,
I'm running a Smoking Airplanes SA-100 with two injectors as well. I've talked about flow rate settings and smoke oil with John (of SA, great guy!) on my visits to Rosamond.
From the discussions with John, he recommended I start by opening the valve 1 to 2 turns (he leaned towards 2). I found that two turns smokes like crazy, but consumes oil pretty fast. 1 turn was a tad light, so I've settled on about 1.5 turns...good smoke, not too fast a flow rate. Not sure what the GPM is at the setting, but I also recall John saying the nominal flow rate is about 0.8 GPM (of course that varies with the turns of the knob!)
So how many turns do you have the valve open to get smoke like that seen in the picture above? If that smoke in the pic is at 0.5 GPM, I'd say that you have a great working system! Very nice!
As for form oil, I've seen many references to Corvus Oil (aka Canopus 13) being the same stuff. Researching it a bit showed a lot of forum discussion references to that, but I have't seen an official MSDS that calls Canopus 13 concrete form release oil. Paraphin-based mineral oil is another term I've seen used for various smoke oils.
There are several threads here and elsewhere discussing various oils for smoke systems...here's a couple from the VAF archives (prices are dated, to be sure!):
http://www.vansairforce.com/communit...ad.php?t=44669
http://www.vansairforce.com/communit...ad.php?t=25538
Appears the search for an economical smoke oil is one of those grail-esque missions (I'm always looking too!) Looking at some sites with barrel prices north of $900 USD was a bit painful tonight. If anyone knows of screamin' deals, lets share...will do if I find one!
Bob
Bob Mills
Old 10-04-2011, 01:30 AM
Andy Hill's Avatar
I'd agree... I display with mine at 1.75-2, the other RV slightly more, to get the same smoke. The difference is somewhere in the system - voltage / pump / piping / exhaust back pressure (?) / injector hole size? Perfectly good to practice at half that rate or less (1 turn?).
I did not pick a random picture For some reason, the angle of the picture, the light, the smoke appears almost 'Space Shuttle' like. More pics available at RV8tors Gallery, or Google/YouTube RV8tors.
Talk to the display guys about what/where they use for oil. Price is only part of it - you need to see how much smoke you get by flow rate, and also consider density v the smoke valve setting v temperature etc. I wouldn't epect to find a "great deal" - it's a commodity. We pay just over $500/55gal + Taxes - but everything over here is more expensive
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
Old 10-04-2011, 06:47 AM
Gerald Loyd Gerald Loyd is offline
Default Smoke Oil
For the guys living in areas where cotton is grown (southern USA) cotton picker spendle oil works OK. Most of the oil distributers stock it for their farm customers. Expect to pay around $400.00 for a 55 gal drum.
Gerald
Gerald Loyd (Bulldog)
RV-4
O-320, Catto 2 blade
Began flying 1963
Old 10-04-2011, 07:31 PM
java's Avatar
java java is offline
Hey Darren,
If you decide you want to try concrete form release oil, I can probably help you with sourcing some.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 12-28-2011, 03:55 PM
C-FAH Q's Avatar
C-FAH Q C-FAH Q is offline
Bob
Bob,
We're you able to try the concrete form oil ? Or come across a suitable cost effective replacement?
I am thinking of adding a smoke system, not sure why, but probably filling the need for more toys.
Gary Wilcox
St.Thomas, Ontario. CYQS
RV7 Sold
www.Facebook.com/Purplehillair
www.purplehillair.com
C-FAH Q now N281CT
gwilcox3 @ gmail.com
