10-01-2011, 10:41 AM
Undecided about smoking
I would like to add a smoke system to my -7. Seems like the smoking airplanes 3.5 gallon, double nozzle setup is best. What I don't know is where to get cheap smoke oil and what type is best. I live up in Calgary, Canada.
Someone quoted something like $10 a gallon. A 3.5 G tank at $35 per which lasts for 5 minutes is a little $$. Any other ideas out there? Or is this just the way it is.
Darren
10-01-2011, 12:56 PM
smoke oils
Darren,
Here's a link for a list of smoke oils: http://www.smokingairplanes.com/smok...m_smokeoil.htm
None are cheap. Some have used diesel and used filtered transmission fluid, but they are not recommended. Good luck and I've enjoyed mine.
Bill McLean
RV-4 slider
10-01-2011, 02:09 PM
As Bill says, none are cheap... However, there are 2 controls to limit the $$ - the on/off button, and the flow valve. Have a think why you really want it, and do you really need the full flow rate?
That said, the full rate can give impressive results:
Diesel works, but it needs higher flow rate to get same smoke effect, and your aircraft may well stink of it for a long time after  The good smoke oils are essentially "baby oil", and smell/feel pleasant
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
10-01-2011, 09:19 PM
Good point about why I really want the smoke...I was just looking for some fun while doing aerobatics. I'm going to check on Monday where I can get oil locally. Still undecided and gathering info..
10-01-2011, 10:31 PM
Andy & Ellie Hill
RV-8 G-HILZ
RV8tors
Nice Picture
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
10-02-2011, 01:38 AM
Darren,
John at Smoking Airplanes may be able to get you a deal on barrels. I think it was about $7/gallon last time I talked to him. Still pricey, and northland delivery may be pricey too.
I've checked with some local petroleum distributors to see if there are any local deals, but no scores yet. You might take the spec sheets from the SA website and show them to the local distributors to see what they might be able to come up with.
I've been told that some of the types of oil are concrete form release oil, so if ya know a tilt-up building contractor, you may be able to get in on a volume buy.
I've used diesel, and it works, and as Andy said, it does smell a bit, and hang time is not as long as the good stuff.
If all else fails, hang out at local airshows, and offer to help them clean up a bit, and if they need that open container of smoke oil disposed of, well you'll have just the place for them to unload it!  (Done it!)
It's expensive by the minute, but its not an everyday thing...and its worth it!
And Andy, that is an AWESOME picture!
Bob
10-02-2011, 08:59 PM
Well, if you need a reason for SAFETY to have it....
... if the tower says they don't have you in sight, flip the switch for a couple of seconds. There! A justification for smoke, because of SAFETY.
10-03-2011, 05:32 AM
One more
It's always good to able to pull the trigger and not have to pick up brass or dead bodies.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
10-03-2011, 05:42 AM
STAY AWAY FROm DIESEL! Thats a ticking bomb and a nasty in flight fire accident waiting to happen! I cant believe someone actually posted this!
Cheapest way to go is concrete form oil. It.s been in used for ever! I see lots of rv,ers use used transmition oil but i am against its use. Too poluting. I personally like to use a brand that contains paraphin wax but it is expensive.
1 galon a minute is the best economic setup. Less than that, save your money since it will look weak. I have a 7 gallons system on mine and it gets used in 5 minutes. It leaves a nice thick smoke trail just like in the pictures posted.
Mitch V.
Semi-Retired in Tybee Island GA
2007 MX2 Nigel Lamb EX RBAR MX2 (Current)
2020 MX2 New Kit Position (Sold at OSH to Team RV Member)
2009 Team Rocket F1 (Sold)
2008 MXS Green Slime"(Sold)
2007 MX2 Patches" (Sold)
1999 Giles 202 "Primal Fear/Perucho" (Sold)
1965 PA32-260 "God Bless America" (Sold)
2003 RV6 "Airhawk One" (Sold)
10-03-2011, 08:58 AM
I had 5 gallons last about eight months.
