Old 09-01-2011, 02:33 PM
meadeduck meadeduck is offline
Default "Squeeky"brakes
Our left brake has started to make a 'binding' sound when the left brake is applied, and the brake is very difficult to engage when you apply pressure. The plane turns to the right much easier than to the left. The plane is difficult to stop evenly when pressure is applied. We bled the brakes and checked the fluid level today. Any ideas??
Meade
N612RV (1/2 owner)
Old 09-01-2011, 04:43 PM
Tony_T's Avatar
Tony_T Tony_T is offline
Default Brake problem
That doesn't sound like a fluid problem, more like foreign material between the disc and the brake pad, or worn out brake pads. In any case, the only way to tell is to take the brake apart and check the components.
That needs to be checked out, and it is easy to do .
Tony
Tony
E-LSA RV-12 ULS
Old 09-01-2011, 04:58 PM
Mel's Avatar
Mel Mel is offline
Or possibly something loose on the assembly causing the pads to bind.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-02-2011, 05:26 AM
VHRV12 VHRV12 is offline
Sounds like a small stone or something stuck between the pad and disc.
Marcus Bootle.
RV120215. Empenage complete, Wing kit complete. Fuse complete. Finish kit Complete. Engine Kit 80%. 2018 Paid.
http://www.mykitlog.com/users/catego...819&category=0
Old 09-02-2011, 10:49 AM
rvbuilder1 rvbuilder1 is offline
Default brake noise
pull the brakes apart and put dry lubricant on the pins and inside the hole that the pins slide in. Brake material builds up as the pads wear and they need to be cleaned and relubricated on at least a biannual schedule
L. John Gould
Dues paid for 2014
RV-6A built and certified 1995 and sold 2002
RV-4 Flying since 3-2011. 110)hrs
Old 09-02-2011, 12:28 PM
Geico266's Avatar
Geico266 Geico266 is offline
This is a good time to add... Make sure you are not "dragging" the brakes when you taxi. It is very easy, and common for RV drivers to "ride" the brakes during taxi.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-02-2011, 01:37 PM
Default Brakes
...guilty on the riding-of-the-brakes part; but I pulled the brakes today as we bled them yesterday, and pulled the easy pad and evened it out a little bit and I scored the disk. I had one of the mechanics look at it and he said it sounded as though I needed to 'burn-in' the brakes. So I took it out (before I took the brakes apart) and taxied while riding the left brake. Then I did a couple of tight circles and still made the wierd noise and it continued to not hold as well as the right. After I did the work on the brakes, I DID NOT test them
Old 09-02-2011, 02:27 PM
Geico266's Avatar
If you needed to even out the pads by removing brake pad material you need to replace the brake pads. Then follow the proper procedure for "seating" the pads. To get the brakes working even again I would do both sides.
Old 09-02-2011, 02:28 PM
JBPILOT JBPILOT is offline
Default Hey Meade - -
You can take BOTH brake pads off and lay a piece of say 320 sand paper on a FLAT surface, and put the pad on the paper and sand the pad until the smoothness is gone from the pad surface. ( looks hazy ). Can also do the disc with the same 320 paper. Go in and out rather than around the disc, just on the area being used by the pad. Tape off the inner part if you want to stop corrosion on the unused area of the disc. Should take the sound away.
John Bender
Old 09-06-2011, 07:36 PM
dick seiders dick seiders is offline
Hey Meade, don't you mean "squeaky" brakes? Very nice meeting you and George at LZU last Saturday. Come on down to 9A1 3rd Sat. of month.
Dick Seiders
