Old 08-24-2011, 03:59 PM
bhester's Avatar
bhester bhester is offline
Thumbs up My recommended tool list
Cleveland Aircraft Tools
CF-80 C-Frame Tool $ 175.00
CL-332 100 Cleko-Loc 3/32" Fasteners $ 44.00
CL-18 50 Cleko-Loc 1/8" Fasteners $ 22.00
CLP-20 Cleko-Loc Pliers $ 7.00
DBJ-40P #40 Drill Bits - pkg 6 $ 7.00
DBJ-30P #30 Drill Bits - pkg 6 $ 8.00
SPR-20 ProSnips - Left & Straight $ 16.00
SPG-22 ProSnips - Right & Straight $ 16.00
DBU-1 Unibit Step Drill 1/8-1/2by32nds $ 19.00
MP-30 Permanent Markers - pkg 3 $ 3.00
FP-200 Fluting Pliers $ 36.00
DB-04 Hex Deburring Tool $ 17.00
BB-74 Mini Bucking Bar $ 22.00
RG-2X Rivet Gun (may sub any gun) $ 187.00
RGS-25 EZ Change Retaining Spring (w/gun) $ 0.00
ASRD14 Swivel Air Regulator $ 32.00
RSM-10 1" Mushroom Set $ 14.00
RSC-43 1/8" Cupped Set $ 8.00
RSB-35 Back Rivet Set $ 23.00
RSO-48 Double Offset 1/8" Cup Set $ 23.00
CT-196 Micro Stop Countersink Unit $ 28.00
CC-40 Countersink Cutter - 3/32" $ 9.00
CC-30 Countersink Cutter - 1/8" $ 9.00
BBRP-48 Back Rivet Plate $ 25.00
DIE426-3 3/32" Dimple Dies $ 36.00
DIE4263CQ Close Quarters 3/32" Dimple Die $ 19.00
DIE4264 1/8" Dimple Die $ 36.00
HS-30 Offset Hand Seamer $ 35.00
DBJ-10 #10 Drill Bit $ 2.45
RSMS75 Swivel Mushroom Set $ 43.00
DBSSET4W Drill Stop Set of 4 $ 7.50
CLC50 4 1/2" Cleko Clamp $10.00
CLC100 4 1" Cleko Clamp $11.00
CDM25 Cutoff Mandrel $7.00
CD30 Cutoff Disk 3" $6.00
RS06 Stainless Rule $8.00
You may customize the kit to suit your individual needs.
Directions are on their website on how to get the discounted kit price
on your customized kit.
Avery Tool
1007 Shop Head Rivet Gauges $17.00
615 Bucking Bar $23.00
1042 Edge Rolling Tool $19.00
The Yard
16305 Texas Hand Squeeze with 1-1/2 & 3" Yoke $129
16310 Quick Change Pins 3 pcs set $6.00
16307 No Hole Yoke $39.00
Harbor Freight
1611 115 piece Titanium Nitride Coated M2 High speed Steel Drill Bit Set $60.00
94585 3/8" Reversible Drill with Keyed Chuck & Key $20.00
47257 6" Digital Caliper $30.00
52847 1/4" Rear Exhaust Air Die Grinder $20.00
32046 Air Angle Die Grinder $20.00
93981 4"x36" Belt/6" Disk Sander $100
67035 4" Swivel Vise $50.00
Lowes
DeWalt 12v Cordless Drill with two batteries $
Cordless Screwdriver (for deburing bit) $
Shop around and find the best deal. Another places to compare prices is
ATS - Aviation Tool Supply
You can request a free catalog from all these places.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 08-25-2011, 05:51 PM
HBpilot HBpilot is offline
Thanks for your help.
A builder friend highly recommended one of those tungsten bucking bar. Are they really exceptional ?
If yes, which size/form would you recommend ?
