Old 08-24-2011, 03:57 PM
Tram Tram is offline
Default Removing vacuum pump from O-320? Magic words?
Ok I'm trying to pull the pump. I'm doing good on 3 out of 4 nuts.
Top left (if seated in aircraft looking at engine) appears to be on a stud, won't be any problem as soon as I get bottom left out.
This is the one I need the magic words for. How on earth do you get to this nut??
Old 08-24-2011, 04:31 PM
n8zg's Avatar
n8zg n8zg is offline
No magic words that I'm aware of, but this'll help a bunch:
http://www.cleavelandtoolstore.com/p...?number=WVP716
Neal George
Navarre, FL
CherokeeJet N9586J
RV-7 N8ZG (all the loose ends)
Continental Aerospace Technologies, Product Support
Old 08-24-2011, 05:48 PM
Hmm.. $35 tool for a onetime job. Maybe the local AP will have something I can borrow.
Old 08-24-2011, 06:44 PM
cholladay cholladay is offline
Yea, if you don't have that tool and you have a vacuum pump you need to get one.
Chad Holladay
Heritage Airpark TE86
RV-8 N769CE Sold
RV-10 N529W flying
RV -8 Building
Old 08-24-2011, 06:46 PM
tmbg's Avatar
tmbg tmbg is offline
cheap wrench + cutoff saw + welding skills.
If you don't have the skills, then you gotta have the bux
Ian
Old 08-24-2011, 07:00 PM
Just had a Hobart 187 show up. Maybe this should be my first project with it.
Old 08-24-2011, 07:02 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
I have first hand experience that all you need is a cheap wrench and a torch of some sort to heat it so you can bend it to the required shape. The dedicated tool works easier though.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 08-24-2011, 07:09 PM
RVadmirer RVadmirer is offline
When I picked up my plane the pump was dead and I insisted on a new one for the trip cross country. Ordered one overnighted from Cal to FL and watched the mech. install. He used a flat blade screwdriver and light hammer to loosen the nut and re-tighten it. He was very careful and tapped lightly on the lobes as needed to loosen and reinstall. Still doing well after 507 hours.
Would love to pull it and clean it so it goes another 500 hours, as I hear they can if one routinely cleans them, but it's a process....
Good luck.
Old 08-24-2011, 07:21 PM
Yeh, I just need it removed. Our EFIS should be here soon and the vacuum system is on it's way out.
Old 08-24-2011, 07:35 PM
CraigC CraigC is offline
Snap On carries a tool for this also.
Craig C A&P/IA
Mesa, AZ RV-8 SerNo 82582
Wings/Fuse N18VA Res
