Old 08-21-2011, 12:28 PM
Dennis_I's Avatar
Dennis_I Dennis_I is offline
Default Possible to build fuse without wings?
Hi
I`m about to order a RV-8, my plan is to get a slow build fuse and order QB wings when everything else is done due to lack of space for storage... My Dad (Prev RV-4 Builder) mentioned that i can not build the "box" in the fuse without having the wingspar available... Is that true on the pre-punshed -8?
Thanx
/Dennis
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
Old 08-21-2011, 12:56 PM
Andrew Sego Andrew Sego is offline
I built my -7 fuse before my quicklbuild wings came in. Might be different with the -8 but I kind of doubt it.
Old 08-21-2011, 01:02 PM
jthocker's Avatar
jthocker jthocker is offline
What was absolutely true for your Dad is not true for the RV8. What you suggest is perfectly acceptable. As a matter of fact, that's exactly what I've seen done a number of times. Slow build fuselage and QB wings is a good plan!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 08-21-2011, 02:33 PM
Dennis_I's Avatar
Allright! Thanks for the replies, lets order a kit!
Dennis Isaksson
G?llivare, Sweden
Old 08-21-2011, 05:56 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default yes
yes. you have to order the center spar with the fuse. about 900 or so.
when you order the wing kit, you can ask not to send the center spar in the wing kit. I am doing this now with my 9a.
Al Girard, Newport, RI
N339AG
RV-9
Old 08-21-2011, 10:47 PM
SHIPCHIEF SHIPCHIEF is offline
I went the other way, building the wings, then getting a QB fuselage.
I had the send in the center section so the QB builders could install it in the fuse.
For me, the center section came with the wing. It's drilled to the spars.
Just call Van's. They will tell you what combinations will work and why.
I ordered the QB fuse when I fell behind a friend building an RV-6. Van's had recently announced that QB components could be ordered instead of a whole aircraft.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 08-22-2011, 04:36 AM
hendrik hendrik is offline
Talk to Van's. They put some of the fuse parts into the wing kit, like the longerons.
Hendrik
Club-Libelle: flying
RV-8: on hold (new job , new home , no workshop (yet) )
Old 08-22-2011, 08:22 AM
gpiney gpiney is offline
The current -1 RV-8 Fuse kit has the wing center section as part of the kit. The only thing you need to order extra is the 'Longeron Kit'. which contains the longerons and the extra angle you will need for fabrication. A box and a long PVC tube are delivered.
Greg Piney
RV-8 2547
Empennage Done!
Beginning Fuselage Final Assembly!
(Tub finished, on to Landing Gear).
Old 08-22-2011, 12:24 PM
rv8@ph-cya.nl rv8@ph-cya.nl is offline
Yes, that works fine. Mind the longerons indeed, ask me how I know...
Good luck, Duncan
Old 08-22-2011, 12:47 PM
Dennis_I's Avatar
Emailed Van`s my order incl the query regarding this... As i Understand it after reading on Van`s web page, You can build the fuselage without wings but not the opposite, then you need to send your wing spar box to van`s for some reason...
Dennis
Dennis Isaksson
G?llivare, Sweden
