hi guys,
well i'm getting things drilled on this tank now and am shaping those little t-410 plates on the inside of the ribs, two of them. i've noticed a gap between the nose rib and leading edge of the skin on every one of them. don't think i can get the rib in there any tighter, tank assembly goes together fairly easily now as i've had it apart a couple of times(having to tweak the ribs a bit to get them to fit in there better), baffle is on and drilled. just don't want to shape those plates if i need to work those ribs in further? looking for any other builders that i'm sure have run into this little issue and suggestions.
