Old 08-18-2011, 12:59 PM
Sig600 Sig600 is offline
Default Dual Pmag issues from owners?
Made the desicion/order to go with dual Pmags from Lycon.
Anyone out there with dual Pmags have anything to report as far as troubles or issues? Any issues with starting? Dangers cranking on less than a full battery? Anything you would change?
Unrelated, any reason to go with a dual alternator or dual battery setup with a G3X panel?
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 08-18-2011, 01:02 PM
unqualified unfluencer
Originally Posted by Sig600 View Post
....Anyone out there with dual Pmags have anything to report as far as troubles or issues? Any issues with starting? Dangers cranking on less than a full battery? Anything you would change? ...
I have had dual Pmags for about a year and a half now, and they work as advertised. No issues whatsoever. One unforeseen benefit was how smoothly it now idles at about 600 RPM - you can almost see the tips going around.
Doug Reeves (your host)
Old 08-18-2011, 01:05 PM
Brantel's Avatar
Brantel Brantel is offline
Not a dual setup but I sure have enjoyed my single Pmag along with a Mag. Starts like a car every time...nuff said for me.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-18-2011, 01:14 PM
N520TX's Avatar
N520TX N520TX is offline
Default Dual
Dual p-mag user for 300+ hours on O-360 firing NGKBR8ES auto plugs. Wouldn't change a thing.
Ron Walker - 40XS
RV7a - Flying
RV10 - Flying !
FFI Flight Lead - www.FalconFlight.aero
Old 08-18-2011, 01:41 PM
Toobuilder's Avatar
+1
... and, when doing the mag check at runup, the only way I can tell one is shut down is the EGT change - RPM does not move one bit.
2 airplanes with dual Pmags... Very happy customer.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-18-2011, 01:43 PM
Jim Kiloh's Avatar
Jim Kiloh Jim Kiloh is offline
Default P-mags
Been flying 3 years with a dual p-mag setup, no issues what so ever, starts first time every time, runs smooth all the way down to 600rpm as Doug said. No way would I even consider anything else.
Jim K
Cypress, TX (T51)
RV 7A-
O-360-Dual P mags-GRT EFIS-Tru-Trak AutoPilot
Flying as of 9/7/08
Finally painted 2/8/13
Old 08-18-2011, 02:09 PM
cguarino cguarino is offline
Default They're Grrrrreat!
300+ hours. One failure that Emag fixed. Wouldn't change a thing.
Charlie "T.Bear" Guarino
Springtown, TX
RV-4 Flying again with a fresh overhaul
Exempt but paid
Old 08-18-2011, 02:16 PM
pmnewlon pmnewlon is offline
was running last year when I bought my RV4 with one PMag, one EMag. I had PMag rebuilt and EMag rebuilt/upgraded to PMag. Started last weekend after sitting for seven months - first blade! Smooth as silk.
Brad was great to deal with too. I also bought the auto ignition wires from him, I'm switching to auto plugs.
Here's a pic - wiring not dressed yet so be nice
Old 08-18-2011, 04:41 PM
apkp777's Avatar
apkp777 apkp777 is offline
Sig,
I have 180 hours on my dual Pmag set up. I did have one of the screws that bind the wires come loose. I don't love how they have the wiring attach. at some point I would like to improve the connections. I don't know what solution I would use, but if anyone has any ideas I am all ears.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 08-18-2011, 05:11 PM
Bavafa Bavafa is offline
Can some of the existing users that moved from mag to Pmag provide some tangible data? Affect on fuel consumption, perceived power gain and perhaps temps.
I have heard that we should expect higher CHTs, if so by how much did your CHT raise compare to regular meg?
Thanks in advance for all info.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
