Andy, I trimmed to fit, applied 4" strips of masking tape to all four sides. Then cut masking tape to provide quick alignment during installation. Have a helper, have everything roughened with 80-120 grit, cleaned with 91% isopropyl, caulk the toothpaste consistency 45 on and push in place. 1/4"-3/8" bead. No washers, no brushing, no mixing, no running.
You'll have electrical tape applied just inside of fg edges and over factory protective plastic. Plastic should be trimmed about 3/8" from fg edge. This allows elect tape to stick/protect windows.
Quickly run a gloved finger to form fillet. Let it cure about 3 min and pull all tape off.
Call if you have any other questions.
Good judgment comes from experience, and a lot of that comes from bad judgment.
