Old 08-13-2011, 06:59 PM
John Collier John Collier is offline
Default MS25041 Press-to-Test Issue
I've got a standard MS25041 light that is becoming intermittent upon pressing to test and with it's associated switch ON indication. Thought i'd see if anyone has an easy fix/suggestions before removing from my panel. It works with just the right "wiggle" and side pressure.
Thanks!
JC
John Collier
RV8
N774BC
Niceville, FL
Old 08-14-2011, 01:28 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default Corrosion
Sounds like dirt/corrosion. Remove the bulb and clean the base or replace it. Also, use a Q-tip and acetone or alcohol to clean the innards.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
