  #31
Old 08-13-2011, 03:36 PM
elippse elippse is offline
I built a prototype dual-redundant EFI which uses timed injection, not a dribbler. It has been flying for at least four years. The injectors only need about 1-2A depending on MAP and rpm, but the 43 psi pump requires up to 7-10A, which is load dependent.
Old 08-13-2011, 04:30 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
What's a dribbler?
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 08-13-2011, 04:53 PM
rcpaisley's Avatar
rcpaisley rcpaisley is offline
Default EFII fuel pressure
Hi Charlie,
We run the fuel pressure on the electronic fuel injection system at 35psi.
This is at the lower end of the spectrum of pressures you will find with EFI systems. We chose the lower pressure so as not to encourage leaks on the high pressure end of the fuel system.
As David mentions, the fuel pressure tracks manifold pressure with our system as it does in most cars. This presents a constant pressure across the injector valve as manifold pressure variations occur. This is a common scheme in EFI systems to make injector timing calculations easy for the ECU.
Robert
EFII www.flyefii.com
Protek Performance
Old 08-13-2011, 08:00 PM
chaskuss chaskuss is offline
Originally Posted by rv6ejguy View Post
What's a dribbler?
Ross,
I believe he is referring to a constant injection system, as opposed to the more sophisticated SFI [sequential] systems.
Charlie
Old 08-13-2011, 08:04 PM
Default Injector electrical draw
Paul,
Your quote of 1 to 2 amps for the injectors, is that each? or for all 4 combined?
Charlie
Old 08-15-2011, 10:28 PM
What's a dribbler?
That's a name I use to describe an EFI that constantly squirts fuel into the intake manifolds at a high rep rate but in varying periodicity, as opposed to a timed injection, as in mine, which always starts the injection at TDC, then shuts it off at a predetermined time based on intake charge density and mixture setting.
Old 08-16-2011, 11:25 AM
rv6ejguy's Avatar
I'm not clear if you are referring to TBI systems or port type systems here? You do know that many modern timed/ sequential OEM automotive port EFI systems start injecting on a closed valve?
Old 08-16-2011, 07:48 PM
Can't say as I do, Ross. I'm really not familiar with more recent automotive systems. The older ones I rread about just had a fixed frequency injection rate and controlled the opening time. The one I've designed has the injectors located in the intake manifold several inches downstream from the valve. When I start injection at TDC the valve is slightly open and the spray of fuel toward the valve will, I think, get the charge in the intake manifold flowing toward the valve to overcome the gas inertia which is still not seeing the pressure depression in the cylinder. Because the injectors are located on the bottom of the engine they don't heat soak so there has been no hot-start problems at all.
Old 09-24-2011, 01:41 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Originally Posted by Sig600 View Post
I've been reading and talking to guys for a long time on this subject, and have gotten 50 different opinions. I understand the pro's/con's of the different variations (emag, pmag, lightspeed, slick, etc) but I can't come to any conclusion on how to setup the ignition based on the options or real data. Dual Pmags, one Pmag one slick, or one Pmag one Lightspeed are the three combos I've come down to...
Thoughts?
No one answered you... and I will keep the status quo... It is 100% YOUR decision, pocket book, choice and preference. If as you say understand all the pro's/con's of the different variations, then you can decide, unless you want me or some one else to tell you. What do you want? Do you max performance, cost no object? dual LSIII's and a back up battery. Good enough easy to install, dual P-mags. Is money an issue? MAGNETOS! Spend less money and time wiring, especially if you already have mags that came with the engine.
WHY EVEN DO EI? Because it does lower fuel burn (more efficient) and increases power. There are not to many mods that lower fuel and increase speed! Drag reduction comes to mind as win-win mod. Carb to FI is a fuel saver but not much gain in HP. The gains of EI are not huge, so the cost of EI over mags will never really pay back... However ONE EI is the most bang for the buck. A second EI does help but marginally.
1) As much as some bad mouth mags, I never had issue with for many 1000's of hours in many planes, BUT if you buy a new engine with a set of slicks that is the easiest, cheapest way to go. They will work, be safe, reliable. The only time mags were terrible was when they got the bright idea to drive two mags from one drive, on odd ball Lycs engines. Bad idea to state the obvious. I recall looking at new Lyc clones and asked about leaving the mags off... they discount was small.... it would be better to keep them and sell them I think.
2) There are only three main electronic ignitions systems on the market PMAG (they don't make EMAGS any more I believe), Lightspeed and Electroair. The first two are most popular. None of them are cheap, and with the PMAG price increase they are $1,375 with with wire harness. The cheaper LS is the plasma II $1,120 complete, but its not going to have the umph of the top end Plasma III model with MSD (multi spark discharge). This over comes the one draw back of CDI (capacitive discharge) short duration. CDI is always HOT or HOTTEST, but MSD adds some fatness to it. So you are going to realize the full potential of the LS system by going with the LSIII which is $1,395, about the same as PMAG. The PMAG's "induction ignition" will drop in spark voltage at higher RPM, wherea CDI or MSD ignition will not drop. However at a 2500 RPM Lyc (even with the wasted spark) the PMAG should be OK. The LSII should still be better than PMAG in performance, but enough to make the difference? May be but depends on you. If you go LS consider the plasma III. Electroair is $1,275 in the middle At least one EI (any brand) is your best bang for the bucks assuming you have one good magneto. However dual EI is going to cost at least $2240 to $2790. The cheapest is the Plasma II at $1,120. The light speed prices are with crank trigger (which is improved). LS with magneto hall effect unit is almost a $200 option. So you can easily get two Plasma III's with hall effect up to $3000! That is a lot of cash. For grins, two brand new slick mags outright are about ($1600) and harness ($375), total two new mags and harness $1,975! So it's cheaper. However if you get a new engine from ECI or Superior, mag credit I recall is small. Keep them and sell them...
3) Zero, One or Two EI? Cafe did tests, compared two mags to one mag + one EI (early Jeff Rose Electroair) vs two EI. There was a noticeable improvement with one EI. The second EI was a slight but measurable gain. As was mentioned EI works better at lower power, because the MAP sensor will advanced the timing (on a very conservative schedule). Mags are 25 deg BTDC all the time which is worst case max power timing. Fixed mag timing works OK in an engine that runs operationally from ~2300-2700 rpm from 18" to 25" of map. It's a compromise and protects the engine from detonation. The EI can advance a lot more, but the EI does not do it until the map gets fairly low. The EI is STILL better at higher power power, with the retarded timing equal to the mag, simply because it's a hotter fatter spark. EI is always going to give a HOTTER spark, may be longer, be more efficient by burning more of the fuel in jug. There is no problem going with one mag, one EI. It may be easier and save adding a back up battery, diode, switches. Again one EI gets you 90% of the gain. (I pulled that number out the air for illustration).
Light speed is CD (capacitance discharge) ignition, as was mentioned, has lower battery drain, may be better if the alternator dies. The single spark is short duration but the multi spark version is longer, which cost a premium. The Lightspeed will give more performance with advanced (racing) features (advance degree display and control, rpm and map output*). The LS offers crank trigger firing option AND a hall effect unit for the mag hole, which cost more. (* I just noticed EMAG now offers a serial output if you want to play with the timing curve.)
The E-mag is a induction coil system (aka old but reliable automotive coil ignition, electronically triggered). It's all in one self powered unit... so there you go, may be the best choice for ease of installation. Plugs into the mag hole. I think they came out with a new generation, however they stopped making E-mags I recall (could be wrong). They are all P-mags now just because that is what people wanted. They still use that cheap looking barrier strip for electrical connections. I would like it if they put a pig tail with a mil spec/aerospace connector on it. All the spark wires go back to the PMAG like a magneto or car distributor. The LS has coil packs, which is kind of a pain.
Electroair is kind of like E-mag (induction coil) but with out the ease of installation, kind of like LS with seperate parts. It is a little less expensive than the EMAG. I am sure it is fine... If you want something in between the EMAG and Plasma III this might be it.
There has been reports of problems, whining or genuine Oh @#$% with every one of them... fortunate few and far between. For the PMAG and LS with mag hole driven hall option you need to have or buy mag gears. They are not cheap new from Lyc ... but PMAG I think now manufactures clones of those gears .. Just consider that adds some cost.
Aviation plugs or auto plugs? It seems the automotive plugs are fine and may be better for high voltage ignitions. The spring contact of the aviation plugs can arc.
Safety is the #1 factor, price, then form fit function. They all promise to be safe if installed properly. I don't think you need to go nuts on electrical redundancy, but with out a standard magneto or the p-mag in the mix, it would be wise to have a parallel electrical power source to ignition's.... figure that adds about 5 lbs.
The choice is yours. You know the numbers.... If you have working mags now go with that. You can add one PMAG later or what every EI you want... That will give you most bangs for bucks.... any thing else will be more complicated, more expensive, and the gains will be smaller than going from zero to one EI.
George
Raleigh, NC Area
2020 Dues Paid
Old 09-24-2011, 03:11 AM
Steve Ashby's Avatar
Steve Ashby Steve Ashby is offline
Default CRIPES AMIGHTY! gmcjetpilot is alive!
It has been so long since I have seen you post, I frankly thought you were killed, disabled or imprisoned. Glad to see your point of view back in the fray. Hope you are well. You haven't lost your touch!
Steve Ashby
Stone Mountain, GA
N184RW (reserved)
RV-8A
YIO-360 180 hp Lycoming
Hartzell Blended Airfoil Prop
Engine Hung
