Old 08-06-2011, 07:13 PM
wyoflyer's Avatar
wyoflyer wyoflyer is offline
Default Repairing a friends RV
Can I legally repair a friends RV? Can I charge for this service? Can I return it to service?
Dave Mader
Sheridan, Wyo
RV6, flying
Old 08-06-2011, 07:23 PM
Geico266's Avatar
Geico266 Geico266 is offline
This is a job for Super DAR! Mel!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-06-2011, 07:25 PM
131RB 131RB is offline
Dave,
You didnt state what the damage was. As a repairman technically you can only sign off work on your own airplane unless the type work you are doing falls under what a pilot can accomplish IE preventative maintenance. If memory serves me right any thing requiring a major repair or alteration or will require an IA for return to service.
Ryan
Old 08-06-2011, 07:30 PM
Mel's Avatar
Mel Mel is offline
Anyone can legally repair an experimental amateur-built aircraft and return it to service. Charging for it may not be a good idea unless you are an A&P.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-06-2011, 07:34 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by 131RB View Post
Dave,
Ryan
The repairman certificate has nothing to do with repair and maintenance. It only allows the holder to complete and sign off the condition inspection on the aircraft for which it is issued. An IA is never required for anything on an experimental amateur-built aircraft.
Old 08-06-2011, 08:33 PM
wyoflyer's Avatar
Thanks for the responses guys. The damage was fairly eextensive (ground loop). I'm sure I can repair it but my brother posed the questions to me. He is an A&P, and an IA and is trying tO compare certificated to experimental....always a confusing issue.
Dave Mader
Sheridan, Wyo
RV6, flying
Old 08-06-2011, 09:58 PM
PCHunt PCHunt is offline
Default "Return to Service"
Please correct me if I'm wrong, but I'm thinkin' the words "Returned to Service" may not be appropriate for experimental aircraft.
"Found to be in a condition for safe operation" is what I see in logbooks more often. A repairman or an A&P can make this statement.
Not sure what log entry would be made by someone repairing an experimental aircraft if that person was not either a repairman or an A&P. Perhaps just a statement of work performed, with no mention of returning to service or condition.
Mel?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 08-07-2011, 12:12 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
If anyone can do the work, what is the difference in cahrging for it?
Other than liability of course, and that could be similar with or without an A&P ticket.
I say rebuild it yourself and charge, but have an A&P look over your shoulder and sign off a conditional inspection at the end for his separate fee...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-07-2011, 06:54 AM
Mel's Avatar
Mel Mel is offline
Mel?
Yep, That's pretty much it!
Old 08-07-2011, 08:50 AM
Default Phase 1 ?
Sorry for any misinformation with my original post. Mel, would a major repair or alteration require the AC go back into a phase 1 flight test for a given period of time? And if so who determines how long?
Ryan
