07-25-2011, 08:28 AM
RE: Not Sure
Don't know the answer to that other than I have heard (old age setting in) and can't remember the guru that said it the overall long life of the engine is enhanced by staying above 60 and below 90 in cruise????? I do know ECi put 60 as a minimum cruise pressure.
Maybe Mahlon or one of the other gurus can give the answer
Frank @ 1L8 ... Flying ...
07-25-2011, 08:31 AM
RE: PIX
Originally Posted by rocketbob
True, and that makes two poor designs...
On my rocket I have removed the expensive vernatherm and put the oil cooler bypass plunger and spring, and will control the oil temps manually with a ball valve.
Hi Bob
Do you have pictures and diagrams and parts list for this option. And have you flown your rocket ....
Frank @ 1L8 ... RV7A... Flying
07-25-2011, 08:59 AM
Frank, What is your oil pressure at idle hot? Do you have the vacuum pump housing on your engine? Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
07-25-2011, 09:32 AM
Originally Posted by fstringham7a
Hi Bob
No pics of the valve yet since I don't have it hooked up and haven't flown but got the idea from Larry Vetterman. I do have the bypass plunger installed. The ball valve goes on the oil cooler line and is controlled from the cockpit.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
07-25-2011, 10:17 AM
Where did you read that? I can't find any operating instruction documents from ECI at all. I was told to use the Lycoming materials since they should be the same.
Sonny W
Boise, Idaho
RV-7A Flying!
07-25-2011, 10:43 AM
25 psi is min idle oil pressure or bottom red line
55-95 is cruise oil pressure or green arch ( used to be 60-90 but Lycoming changed it a few years back)
115 is max cold oil pressure or top red line.
I would be fixing it, if it had less then 60psi for oil pressure, in cruise, if it were mine.
Good Luck,
Mahlon ?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
07-25-2011, 12:00 PM
RE:Vac Area
Hi Don
If I am reading your question correctly I have the SD-8 aux alternator on the Vac pad....
Oil pressure at start up (old spring) was 81 and would be at or about 75 to 80 at t/o. New Spring it was 89 at start up and can't remember the run up temp or pressure and at t/o hit 108
Frank
07-25-2011, 12:20 PM
RE: Info
It took me a while but I finally found the info on the ECi web site. On the ECi Home page there is a square info position on the left side that says Titan EXP....... http://www.eci.aero/ ...... which takes you to http://www.eci.aero/exp/index_exp.aspx ...... then on the left is a box EXP KIT Egines and hit either Over view Brochure or Engine Comparison Chart.
http://www.eci.aero/exp/eng_comparisons_chart.pdf
http://www.eci.aero/exp/eng_comparisons_brochure.pdf
As far as operating instructions Robbie Attaway, local RV drivers, and info from VAF is what schooled me!!!!!!!!!! Plus this info from ECi
http://www.eci.aero/pages/tech.aspx#breakin
Sonny, I hope this helps. So now the race is on who will get their plane dialed in first. I personally hope it is you so I can learn from you.
Frank @ 1L8 ...RV7A... Flying kinda!!!!!!!!!!!!!!!!!!!!!!
07-25-2011, 01:02 PM
Hi Don
Frank
Reason I asked is that I had oil pressure problems with my engine. My pressure would start out 95psi at 100 degrees oil temp, 85psi at 180 and would fall to 50psi at 230. Idle pressure was 15psi hot. Caused a spun rod bearing. The vacuum housing was on the case but without a gear in it letting the oil bypass. Now start up and take off 85psi, lowest it gets in cruise is 78psi at 220 temp. Idle 40-50psi. Sounds like you might have a missing oil galley plug. Don
Next project?
07-25-2011, 09:20 PM
Thanks, Frank. I don't know why ECI doesn't make their own manuals...would make sense, no?
As for a solution, I hope this does make a difference...I'm running out of ideas on what to do next. I really don't want to cut holes for those louvers!
Sonny W
Boise, Idaho
RV-7A Flying!
