Old 07-10-2011, 07:43 AM
L'Avion's Avatar
L'Avion L'Avion is offline
Default dynamic propeller balancer
Looking to buy dynamic prop balancer.
Seeking advice from experience with different balancers - which brand, success, etc,?
Barney, in Memphis
RV-3 & 4 flying
Old 07-10-2011, 08:29 AM
Walt's Avatar
Walt Walt is offline
Default Prop Balancers
You have to decide your budget and mission..
There are high end "professional" balancers and then there are the "hobby" balancers. The profesional balancers offer increased capabilities, are built for rugged use with better components, offer software for storing and printing balance results, vibrations surveys etc. and get calibrated every year, they also cost 4 to 5 times the hobby units.
The hobby balancers are great if you just want to do your own prop balance and maybe your friends. These balancers have less resolution than the Pro units and are not as user friendly as the Pro units. They will do the job but generally are less accurate and it will take you longer (more runs) to get the balance "dialed" in. No ability store or printout the results from these units.
Here is an example of the downloads from my DSS Microvib II unit:
http://www.vansairforce.com/communit...ad.php?t=74081
When I get done with a balance I am able to supply the customer with print outs for Prop balance, vibration survey and a log book sticker.
Dynamic Balancers are available from:
Dynamic Solution Sytems
ACES
Chadwick
DynaVib
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-10-2011, 04:05 PM
sailvi767 sailvi767 is offline
Is there anyone in the Charlotte NC area offering dynamic balancing?
George
Old 07-10-2011, 05:56 PM
Radomir's Avatar
Radomir Radomir is offline
Yes.. I can do it.. Where are you based? You can PM me and I can give you details..
Radomir
RV-7A sold
Old 07-10-2011, 05:59 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
Default Balance
Radomir,
I am located at KCPK in Chesapeake, VA. How far away are you?
I am interested in having my prop balanced.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 07-10-2011, 07:46 PM
Radomir's Avatar
I'm in Charlotte... Tim came down a few months ago and I did his plane..
Radomir
RV-7A sold
Old 07-11-2011, 09:25 AM
jeffmoreau's Avatar
Default Thanks
I will let you know when I am able to come down. How much do you charge?
Jeff Moreau
RV 8A
N888JM/Flying
Virginia Beach, VA
