Old 06-27-2011, 11:53 PM
tikicarver tikicarver is offline
Default which engines have a conical mount?
anyone have a list of which 360 engine models have a conical mount?
Old 06-28-2011, 06:26 AM
mahlon_r mahlon_r is offline
O-360 C and D series.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 06-28-2011, 11:40 PM
Are there any IO-360s with conical mounts?
Old 06-29-2011, 03:57 AM
N941WR's Avatar
N941WR N941WR is offline
If you are asking about parallel valve, 180 HP, IO-360's the answer is yes.
I don't know about if the 200 hp IO-360's angle valve engines come witih conical mounts.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-30-2011, 06:10 AM
No angle valves that I am aware of. If for experimental you could use a conical case on an angle valve engine and you would be all set. 180HP and 200HP cases are the same except for piston oil cooling jets which are easy to add to the 180Hp setup.
Good Luck,
Mahlon ?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 07-03-2011, 11:48 PM
I have an RV-4 project that came with a conical mount.
I want to put an IO-360 on it. I'm leaning toward a 180hp.
So sounds like I'm looking for a parallel valve IO-360.
So anyone know what the model numbers are for the conical mount ones?
Old 07-04-2011, 12:40 PM
jrs14855 jrs14855 is offline
Default conical mounts
The reference for this is Lycoming publication SSP-108. I do not find any IO parallel valve 360's listed with conical mounts. The carburetor 0 360's with conical mount are 0-360-C1F, C1G, C2A, C2B,C2C,C2D,C4F,C4P,D1A,D2A,D2B. For a homebuilt it shpould be possible to convert any of these to fuel injection. If you are overhauling any of the crankcase companys can convert a dynafocal case to conical or vice versa. It would appear to be simpler to simply buy or build a dynafocal engine ,mount.
Old 07-04-2011, 01:58 PM
The AEIO-360-H1B and AEIO-360-H1A as used in the Bellanca/American Champion Decathalon are conical mount engines. The AE series engines are VERY expensive.
Old 07-05-2011, 06:50 AM
yakdriver yakdriver is offline
So if you want fuel injection just put on an Airflow Performance system. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 07-05-2011, 01:39 PM
well if money was not a factor, I would go with a AFP fuel injection system.
I put one on my Long-EZ when he first started selling them to the EXP aircraft market in the early 90s. It worked great. However, the price has has gone up about 4-fold.
My plan is to find a run-out IO-360 with the Bendix fuel injection and overhaul it. I was not aware you can have the case modified. That is good news because I can now concentrate on just finding a good deal on a IO-360 and if happens to be a Dynafocal mount, just have the case modified.
