  #11
Old 06-24-2011, 02:35 PM
N208ET N208ET is offline
Default Try this
Put a small zip tie through The attach bracket where the spring hooks on the control weldment, it will fill up the space enough to keep the noise to a minimum.
Randy
8A
Old 06-25-2011, 05:09 AM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
Default RV6/7 or 4/8?
If you change tanks every 1/2 hour, you will never pull the springs as far as you are sitting in the plane without flying it. Very little adjustment is needed when in actual flight.. In a side by side model, the aileron adjustment is needed more only if the pilot is solo and is "full figured" (re: 200 or more lbs). When the right tank is lower, you will notice an out of trim position.
Woodman
Old 06-25-2011, 09:29 AM
benbell4140 benbell4140 is offline
I think I will just leave the springs off for now and if I need trim in the future I will pit the springs back on. Thanks everyone for the ideas.
Ben Bell
RV8 (sold)
Awaiting Kitfox SS7 kit
Old 06-25-2011, 11:29 AM
flyenforfun's Avatar
flyenforfun flyenforfun is offline
Default Heat shrink tubing
I put heat shrink tubing on the ends of the springs and it seem to help a little
Matt Giordano Sr. and Jr.
RV-8 - N861MM
Wilmington, DE
Old 06-27-2011, 12:00 PM
cdmiller's Avatar
cdmiller cdmiller is offline
Default The zip tie works
Randy
8A
I did as Randy suggests. By putting a zip tie on each side where the spring hooks to the control weldment, the spring is not able to move about with aileron movement. This simple solution has worked for me for nearly a thousand hours. I like the aileron trim and would not remove it.
Dan Miller
RV-8 N3TU 970 hours
Old 06-27-2011, 12:19 PM
I will give the zip tie fix a try, thanks!
Ben Bell
RV8 (sold)
