05-31-2011, 02:28 PM
Idea for Flap Handle
I had opted for the Ray Allen grips and PTT, but my flap handle looked chintzy. Ray Allen will sell you an extra grip for only $6, fits right on the flap handle.
[IMG]  [/IMG]
05-31-2011, 02:45 PM
Hi Don,
It looks good and will work well but it will still eat your hand. When you push the button in to move the flap handle it works like a paper cutter and removes chunks of the hand, good luck.
Best regards,
Vern
05-31-2011, 02:52 PM
Yeah I have noticed that. Am considering filling the gap with bondo or something to help that out. My old arthritic hands can hardly push the button in anyhow, I am going to put in a far softer spring as well.
05-31-2011, 07:19 PM
Flap handle button
We just rounded all the sharp edges on the button...AND we have to push the button in, slightly, when dropping the flaps.
Meade
N612RV
05-31-2011, 07:52 PM
I used Rectorseal EP-200 epoxy putty. Filled in the nail head area and then took it to the belt sander and reduced the dia to the smaller of the two. It is now like a button instead of a paper punch.
Also, if you "ramp out" the second notch on the flap locater, you won't need to push in the button to go to the next lower flaps.
05-31-2011, 08:28 PM
Hey now those are some really good ideas! I like the ramp of the notches idea a lot. Seems like my old Cherokee had such a setup.
Originally Posted by gasman
I used Rectorseal EP-200 epoxy putty. Filled in the nail head area and the took it to the belt sander and reduced the dia to the smaller of the two. It is now like a button instead of a paper punch.
05-31-2011, 09:04 PM
Looks Cool But!
I have a question, how do you get the F-1228 channel cover plate over the Handle?
John
RV12 N1212K
Flying Since June 2010
1020 Hours as of 9/30/2017
Johnrv12@icloud.com
RV14 Wing, arrived and building at Rdog's new Hanger at 16X
S/N 140014
05-31-2011, 09:14 PM
With the handle in the full flaps down position.
05-31-2011, 09:18 PM
Let me ask it differently
Let me re phrase: With the nice handle that Don has in his Picture will it fit through the hole in the channel cover F-1228?
John
RV12 N1212K
Johnrv12@icloud.com
S/N 140014
06-01-2011, 06:35 AM
another potential concern with this
Agree the idea seems like a good one. However, the amount of space between the flap handle and the sides of the seats is relatively small, particularly with the weight of both the pilot and a passenger on the seats where the seat cushions compress and bulge a bit. It is already pretty tight to get my hand around the handle without the additional thickness of a grip. Have you actually tried the grip with seats installed to make sure you can easily get your hand around the handle?
I personally have not had any problems with the existing handle/button design cutting my hand so I don't quite understand what is causing this. If everything is nicely deburred and edges are rounded and the button is adjusted as per the instructions, seems like it would be difficult for the design to cause problems.
Jeff
